Question about The Watches
How do I change the date on my ellesse 03-0471 watch
Posted by Paul Eden on
Brijesh Shah
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
Go to google and search
Posted on Aug 22, 2019
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
Id like to value my ellesse watch, 03-0037 but I cannot find any record of the design anywhere?
Take it in to a jewler to get a estimate on it if it isn,t hot,
Nov 11, 2012 | Watches
Spare bracelet links required for Ellesse watch model 03-0041-201
Hi
Does anyone know where i can get links for Ellesse watches. I have a range of different watches all too small.
Grateful for any help.
Jun 15, 2012 | Watches
Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
Jun 07, 2011 | Hamilton X-Wind H77646733 Wrist Watch
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
I am looking for a user manual (instructions) for an Ellesse watch model # 03-0038-001
i just found the same model of watch in the closet that some one gave me as a gift 20+ years ago. It's in original box with the instruction. The battery is dead (of course). The instruction is one long narrow sheet of paper with small print on both side. Very complicate setup.
Hey Dougnbev, I can scan it and email to you if you want.
Oct 31, 2010 | Watches
I need a Manual for a Ellesse Chronograph Watch. Serial Number 03-0635-501
Their web site is not too helpful, as you may have already discovered!
Try going to http://www.ellessetime.com/ sellect the appropriate region and contact their customer service. They should be able to help.
Sep 04, 2010 | Bulova Watch
Help changing the date on my HYPE wrist watch The watch didnt' come with any instuctions. I don't know how to change the date. I have it on the correct day of the week but I can't change the date?
The date may have a mechanical change at midnight(ish).
f this is the case, take the watch past midnight and then wind it back to (say) 11 and then forward again. Repeat this until the correct date is achieved.
If you watch is an electronic type then press the mode button until the date change function appears (it is likely to be abreviated "DC ? perhaps" and then use one of the other buttons to advance or ****** the date as required. Some experimenting may be required.
Feb 15, 2010 | Watches
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Watches Logo
131 people viewed this question
Top The Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
