I have been having a problem with my above-mentioned turntable. What is happening is that when I load a record onto the platter and press "start" ... questions:if you put the arm on the record without start button,what happens? ... I have a pxe850 in my garage, i think it's a newer equivalent of the pxe800,
SOURCE: I need a spare turntable
I did it by searching the internet rather than being led into a a system which costs money.
JMB
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the
motor spindle by using your fingers to turn the round shaft which rotates
freely. Remove the rubber mat off the platter. Place the belt around the outside
of the drum on the bottom of the platter.
From the top of the platter, place your finger in one of the platter
holes and tension the belt so it will not fall off or twist. Griping the
platter trough the holes while keeping tension on the belt place the platter on
the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over
the motor spindle. Replace the rubber mat on the platter.
SOURCE: I have the Aiwa model
It does have a built in preamp which can be switched off if desired. The switch is located in deer the turntable platter towreds the rear of the unit. You can easily access the switch through one of the holes in the platter.
