Washer is only filling with hot water washer has been sitting for a few years.
Posted by Helen Madrid on
Jim Hicks
    Master:
  • 661 Answers
I don't know. check to see if cold water is availabe. shut off hot and cold supply taps. start washer to try to reduced pressure on rubber hoses. shut off washer and disconnect it from hydro. undo cold water rubber hose at the washer. point it into a pail or sink and slowly open supply tap to see if water flows freely. if no water, clean or replace both hoses as they deteriorate with age. if water
runs freely, i think you may have to replace the intake valve on the washer. they usually are easy to disconnect and replace.
Posted on Aug 22, 2019
5 Related Answers
Anonymous
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Hot water fill problem
Replace or clean your water inlet valve. It appears that the hot water solenoid has either become clogged, or had failed. You can find a replacement at repairclinic.com. Type in your COMPLETE model number in the Search window and there will be two of them located under the "Water Valve/Float" heading. Depending on WHICH type of valve you have, a replacement costs between $28 and $74. Refer to the part illustrations to make sure you are ordering the correct part. If you require assistance in accessing the inlet valve, let me know. I hope this helps you.
PS If you attempt to clean the valve, you will need to turn off the water supply and disconnect the hoses. Check the inlet screens for sediment or debris.
Posted on May 28, 2008
SOURCE: Kenmore Commercial washer 110.20172001
Sounds like motor is bad. See if you can find the 2 main wire leads on the motor and hook up directly to see if you can get it to work.
Posted on Mar 05, 2009
SOURCE: no cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
Posted on May 29, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Posted on Jul 19, 2009
I have a GE stackable GUD27GSSJWW - we are on the second one with the same issue. The washer will begin to fill (wash or rinse cycle) and then just stop and the lights start flashing.
It may not be the washer. Have you checked that the filter on the water inlet has not got partially blocked with rubbish from your water. This is a common reason for a fault like this. You will need to remove the washer, remove the water inlet hoses and then remove the inlet filters and clean them. I was given a very expensive washer a few years back that refused to work for the owner who bought a new one. After cleaning the filter, it continued to work for many years after that.
Dec 08, 2017 | GE Washing Machines
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
Maytag Centennial is filling with hot water on cold setting
Probably the fill lines were reversed. The installation guidance tends to be poor.
Jun 15, 2017 | Washing Machines
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
Washer stops during cycle with FH error. Drain and all is fine. Washer thinks the water supply in not sufficient but water output is fine. Has done this a few times over the last couple of years. Last...
This is symptomatic of an intermittent malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 02, 2011 | KitchenAid KHWS01PMT Front Load Washer
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag clothes washer won't fill with hot water
Then you most likely have a bad hot water valve. On Maytags the valve is one combo unit for both hot and cold. Maytag didn't change that much for a number of years, so you may be able to salvage one out of an old machine somewhere and fit it in -- that's what I did when my wife's Maytag did this.
Dec 30, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
