Question about Kohler Electrical Supplies
Is the wiring diagram the same on a confident 5 as a confident 4 RV kohler generator?
Posted by Karla... on
Tom Chichester
    Top Expert:
  • Kohler Master
  • 55,983 Answers
Request the diagrams from Kohler and compare.
Posted on Aug 21, 2019
1 Related Answer
Fred Yearian
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
HOW DO YOU REMOVE FULE FLOT BOWL KOHLER CONFIDANT 5 5CKM21
It is not a float issue because the motor cannot consume the entire contents of the gas chamber in one instance of a surge. This is a throttle issue.
Oct 05, 2015 | Kohler Electrical Supplies
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed ....
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Oct 21, 2013 | Electrical Supplies
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
Electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Schematic
I looked for several minutes and this is what I found:
Kohler 13EOZD wiring diagram
I went to the Kohler site, entered the number and it cross referenced to the above number. The wiring diagram is on page 90.
Hope this helps!
Oct 20, 2008 | Electrical Supplies
Electrical Supplies Logo
117 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
