Question about Manitowoc Kitchen Appliances - Others
SOURCE: Ice sticking to ice maker
the water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
We suggest u to perform the following checks to solve ur problem...
thank you..
Posted on Apr 08, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
SOURCE: Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Posted on May 14, 2009
Aug 25, 2015 | Kitchen Appliances - Others
May 30, 2014 | Manitowoc Q210 Under Counter Ice Maker
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Jan 30, 2014 | Manitowoc QY-0214A Self Contained Ice...
Nov 20, 2013 | Manitowoc QD0273W-161 Dice Cube Water...
Oct 08, 2013 | Manitowoc Kitchen Appliances - Others
Sep 19, 2013 | Manitowoc Kitchen Appliances - Others
Jul 13, 2013 | Kitchen Appliances - Others
Sep 03, 2010 | Hotpoint Refrigerators
Jul 24, 2009 | Maytag MFI2568AE Side by Side French Door...
128 people viewed this question
