Dometic RML 8555 Door is locked and release won't operate. How can I access the release mechanism?
Posted by Barbara Marlow on
Andrew Taylor
    Top Expert:
  • Washing Mach... Master
  • 33,350 Answers
Turn off the power. The lock is electromagnetic.
Posted on Aug 21, 2019
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Door lock stuck
If the mechanism is jammed, you might have to remove or loosen the entire front panel to reach back to the back side of the lock and work on it.
Posted on Feb 25, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Posted on Oct 03, 2007
Anonymous
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Anonymous
  • 1392 Answers
SOURCE: how to unlock a broken ford windstar rear door
You will need to remove the hatch panel, and release it manually. It is a pain in the **** with the hatch closed, but it can be done.
Posted on Jun 05, 2009
Anonymous
  • 20 Answers
SOURCE: rear passenger door won,t open or lock when driver
you may have a blowen fuse check them and relay to that door
Posted on Apr 17, 2010
My door won't close at all bounces back a bad lock on a ford ka? i wil buy another lock but do i need to get the key of the new lock or i an stay with the one i have?
door lock latch is closed you need to release the locking mechanism at the side of door with screwdriver while holding door handle open to release the latch then door lock will operate as normal
Jan 20, 2014 | Ford Ka Cars & Trucks
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
Locking Gas Door will not open when release button is pushed. Solenoid snap can be heard. Trunk pull-cable will not release latch either. Can release be accessed from trunk-side via carpet...
Trunk pull-cable Access Is by way of IN TRUNK, A HIGH QUALITY SPRAY TYPE Lubricant Should Be Used here to Free Up Mechanical Parts, Allowing for Proper Operation of this Door
Nov 28, 2010 | 2002 Jaguar S-Type
2004 Chevy Trailblazer - Randomly the liftgate does not unlock. Have to crawl in the back and manually release the lock through the small access hole. Doesn't seem to matter how many times I cycle through...
That's one of those thing you will need to look at. check the electric solenoid to make sure it has a good ground and "hot" connection. Also make sure that the lock mechanism is operating freely and not binding.
Jun 21, 2009 | 2002 Nissan Altima
Nissan Altima fuel filler release latch broke ... need alternate
Never heard of anything like that.  But those latches are not as secure as most think, just take a flathead screwdriver, put a piece of cloth around it to protect your paint, and pry the door open, just when you think it's about to break something...pop, it opens just like that.  I've done this quite a few times, only broke one so far.  :-P
Jan 23, 2009 | 2000 Nissan Altima
Asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Oct 13, 2008 | Washing Machines
Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
