Question about The Office Equipment & Supplies
Causes of the informal sector with statistics
Posted by Annerien van... on
Don A
  • The Master
  • 2,620 Answers
The informal sector refers to the "off the books" economy, the labor force not monitored by the government, essentially people "paid under the table." This sort of labor is not taxed because it is unreported. The money generated is not included in official statistics such as the GDP of a nation. Just how data is accumulated about such is a bit of a mystery to me, just as much as the estimated sales of any ******* drugs would have me wondering how the data was accumulated. However, you can find papers about the subject. I simply cannot assure you regarding the validity of the data. As aways, you must consider the source.
The following paper does list some causes but I leave it to your hands to determine the merits of the paper.
https://www.ilo.org/wcmsp5/groups/public/---dgreports/---dcomm/documents/publication/wcms_626831.pdf
https://news.un.org/en/story/2018/04/1008562
Posted on Aug 21, 2019
HOW WOMEN PARTICIPATION IN INDIA'S FINTECH ECOSYSTEM CAN BE INCREASED?
The statistics indicate that the Indian financial system is lopsided in phrases of gender equality at workplaces. What can be the reasons for a lower team of workers participation of women in India? While fintech sector continues to grow, there are still very few female professionals and leaders in this space. While this is the case, I have also come across a company called FlexiLoans, who provide small business loans for women in India.
Aug 16, 2018 | Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Is there an Internet source of information to describe the population estimate of all Deutsche Post two digit Postleitregions ?
There is a German language spreadsheet of official population estimates available from the Federal Statistical Office of Germany. I am unable to advise exactly how it is broken down, as it is in German, which I cannot speak.
State society Population projection Federal Statistical Office Destatis
Jan 02, 2015 | Games
I have a transcend jet flash v33 4Gb. I save files in it and then safely remove it, the next time i access the file it is already corrupted. I tried to format the usb but it still have the same problem....
Cause of damage is bad sectors
Transcend repairing bad sectors, you can see my blog.
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". View the the video tutorial "Repair Transcend Bad Sector"
Hopefully this information helps
Oct 02, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Asking for formating memory card, after formating says problem with memory card
Usually the process of formatting memory cards wipes off all information on a memory card. If after formatting the cards shows problem with memory card then the memory card has bad sectors which make the card no longer usable.
Bad sectors in a memory card are usually caused by poor storage of information and viruses. Best solution will be to replace the card but if not connect the card to a PC and defragment this will seperate the bad sectors from the good ones. Although you will not have full use of the card size.
Hope this solution has been helpful?
Dec 21, 2010 | Sanyo VPC-CG10 High Definition Camcorder
How can i use casio 991ms to solve all statistics questions
first off you want you calculator in SD (standard deviation) mode to do this hit mode twice and then 1.
next it is good practice to start off by clearing the memory to do this hit shift, CLR,1 and then = this will clear statistical memory
to enter values into your data set , you enter the value, then press the DT (M+) button. (note: pressing DT repeatedly will impute the same value multiple times)
once you have finished pluging in your numbers your calculator can give you statistical information about the data set.
hitting shift then 1(S-SUM) gives you three options: 1 the sum of the squares of each value 2 the sum of each value 3 the number of terms in the data set hitting shift then 2 (S-VAR) gives you three more options 1 x bar (the mean) 2 x sigma n (the population standard deviation) 3 x sigma n-1 (the sample standard deviation)
you can use these tools to solve alot of statistical problems i hope this helped
Source: http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf page 28 of he pdf
Dec 01, 2010 | Casio FX-300MSTP Scientific Calculator
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
18 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
