Question about Lands Phones
IN9015-71. One of the office ext is not working. They do not get a dial tone to call out and there is a busy signal when trying to transfer calls to that number. All other lines are working.
Posted by Abigail Reed on
Jim Hicks
    Master:
  • 661 Answers
I don't know. if possible, switch a working unit with the one that has a problem. that should determine if it is the connection or the telephone. i might just be a 'stretched'
cord that is causing the probem.
Posted on Aug 22, 2019
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Posted on Jan 29, 2008
rmeyer
Richard Meyer
  • 80 Answers
SOURCE: Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Posted on Jan 09, 2009
Chuck Badeaux
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
Anonymous
SOURCE: no dial tone/ others trying to call get busy signal
Turns out that it was a wiring issue and not the phine.
Posted on Jun 20, 2009
Anonymous
  • 23 Answers
SOURCE: When I dial a fax number I get a busy signal even
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Posted on Feb 22, 2010
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
My panasonic kx-tga431al has all of a sudden changed the dial tone. instead of the regular tone, it now has a tone that sounds like a busy signal... what do i do to fix this?
Have you set up 'Call Divert' which returns a 'Broken Dial Tone'
Dial #21# if it is on a Single Line Telephone, or if fitted on a Business System check programme for 'Call Forward'
Jun 30, 2010 | Lands Phones
TRANSFER TO WRONG EXTENSION
This will be an easy fix. It is your night AA selector code. Did you resolve this?
Apr 07, 2009 | AT&T Lucent Merlin SP 34 Phone
Norstar Flash
phone is not programmed for forward busy no answer.
Feb 06, 2009 | Nortel Norstar 16-Line PBX Speakerphone
I cannot dial out.
The dial may be defective and when you dial it is putting out erronous tones. When the Phone Company heres digits that do not correspond to a legal phone number it will give you a error tone or busy tone. It could be the phone got put on pulse and the line won't recognize the pulses
Dec 28, 2008 | Lands Phones
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
Lands Phones Logo
116 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
