Roland Mv-8000 Sampling/Record Production Studio System Logo
Good day... i have a ROLAND MV8000 but i cant create projects. getting this message- OPERATION FAILED. manual dont say anything about this... help please
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on Dec 23, 2007
SOURCE: to create a software
Believe it or not, creating software is easy. Especially these days with the object oriented programming OOP's. A program is just what it sounds like, it is a list of what will happen in order, just like you would see at a concert.
Basic is the best way to start, Beginners All Purpose Symbolic Language. It is the best way because it is in english and has few parameters.
Learning a language is all about learning how to format the commands. Apostrophes, commas, semi-colons, etc have meaning when you input the commands.
You just need to think like the computer does, very literally. A computer does nothing and knows nothing until a programmer tells it what to do. In basic you have certain input/output devices, and everything else is internal.
Okay, here is what you are after:
print "what is your name"
input: X
print "Your name is": X
end:
Anonymous
  • 158 Answers
  • Posted on Oct 01, 2008
SOURCE: operation failed on my se k850i
you may have to reinstall the O.S of the Phone.
They call it upgrading the Firmware and that will fix the issue!
And don't delete any files which are hidden under the folder " System"
That causes this issue
do not alter some files in the phone and it ll not allow u to use any applications and games apart from walkman and the Internet browser!
hope this helps...
good luck:-)
Anonymous
  • 962 Answers
  • Posted on Nov 07, 2008
SOURCE: cant get the authorization code
Contact Adobe . be sure and register your product with them first.it should work.
tzahranul
Fiuciuc Andrei Nicolas
  • 89 Answers
  • Posted on Jan 25, 2010
That happens when your phone memmory is full(i know this might seem odd if you have a memmory card in the phone but usualy when recieving something trough bluetooth or IrDA the file gets stored temporarly in the phone memmory and then it si saved to the location you wanted to!)
Anonymous
  • 2382 Answers
  • Posted on Dec 12, 2010
SOURCE: Roland VS 2480 v2 -
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
I have a Roland Camm-1Servo GX-24, and I am getting a "Report" message and it's powering off or anything
It sounds like there might be an error with the internal software of your Roland Camm-1 Servo GX-24 vinyl cutter. Here are a few troubleshooting steps you can try:
  1. Check the manual: Refer to the user manual to see if there is any information on what the "Report" message might mean. The manual may also have instructions for resetting the machine or troubleshooting common issues.
  2. Check the connections: Ensure that all the cables and connections are secure and properly connected. Also, check if the power source is working correctly.
  3. Check the firmware: It's possible that the firmware of the machine has become corrupted or outdated. You may need to update the firmware by downloading the latest version from the Roland website.
  4. Perform a factory reset: If nothing else works, try performing a factory reset on the machine. This will erase all the user settings and restore the machine to its original factory settings. Refer to the user manual for instructions on how to perform a factory reset.
If none of these steps work, you may need to contact Roland customer support or a qualified technician to diagnose and fix the issue.
1helpful
When Im loading sample via audio cd I keep getting driver is busy and when dumping my beats from mv8000 to any recording software I get a loud buzzing noise.
I'm not really sure what to tell you about loading your sample music. It may be a decoding issue. Check to see if has the same issue with a production music CD. As far as the hum, there can be many issues causing this. You may have a ground lead bad in the cable you are using, from your Production System to, I assume the amp you are using for the output from the Roland. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dell Inspiron N4030 asking me for BIOS password, i dont even rember making one.....I cant Boot to install a new version of Windows and I'm getting P-Offed!! Help please
You may have to find the reset disk or may have to do a clean instal in which case is not fun however
If there was no passowrd created by you always remember to go the easies route >>> My advice look @ the operation manual if no luck then at that point you will have to >>>>> ; )
Dell XP = Ctrl+F11Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come with disks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever put anything on the recovery partition d: , if you used d: for anything you need to remove what you put there or the recovery will not function.
2helpful
My roland vs2400CD keeps getting stuck at the load screen. I have tried the factory reset, but can't complete it. Is there anything else I can try, or do I have to have my hard drive replaced?
Hold the two buttons down above the slider on track #4 when turning the power on. You have something that is corrupt on your hard drive. This bypasses looking for a project to load up and just goes straight to the operating system.
Ever since i hooked up the usb ports from my mv8000 to my vista compuiter my roland wont save or it wont load any projects and also it seems that it erased all my songs that i ever worked on, when i start...
I think the most common cause of this with a pc is that windows media player scrambled the data on the hd.. you need to get a harddrive ide ata adapter , open the mv and connect the hard drive directluy to a computer then copy the files.. then reformat the harddrive in the mv then put the files back on .... i had the same problem with a mac but i dont know the cause since i dont have windowns media player.. im interested to know how this turned out.. i thinking of sending my drive to a drive saver company if it doens work out.. i neeeeeeddd my fillleessss.. aaahhhh
When im loading a project, it shows operation failed
Did you try to scan your disc for bad sectors? Look in the manual and it will show you how to do a surface scan.
3helpful
3answers
"error loading operating system"
Sounds like your Windows XP installation failed. Run the XP install again making sure to delete the existing partition and then create a new partition. You could also have a bad drive out of the box.
TEC 472 Error message- SG: 139, 0010, 064
This is syntax error, the coorect is SG;0139,0010,064....
1helpful
DOES THE MV8000 COME WITH A FLOPPY DISK
Yes, from what I understand, it came with a floppy, CD-Rom, and a 40gb hard drive.
"Setup Drive: Load Project -> Now working... -> Please wait...."
I have 3 2480s and I use them professionally so I think I can help you. Looks as if you need to install the OS for the system. It seems as if it lost. You should have the OS on CD and if not contact RolandUS and get one. You would put in the OS into your CD burner and power up the unit. I would recommend Roland HD support be on the other end if you are brand new. They will walk you through. I was one of the first to buy the 2480 when it came out and the manual is just insane to learn.
Mike
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
