Ariston washer machine code F5 - Washing Machines
Posted by tommy reynolds on
Geir Lland
    Habit-Forming:
    New Friend:
  • 146 Answers
Drain fault and/or pressure switch fault.
Could also be a problem with the mail board
Posted on Sep 09, 2019
1 Related Answer
john_cross
  • 6277 Answers
SOURCE: my washing machine ariston et
Ariston (Indesit) F05 probably indicates that the drain motor filter is blocked and needs cleaning. Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
Testimonial: "Thanks John!"
Have a Kenmore 110.2632410 top load washer. Getting error code F5. Lid lock is just clicking.
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Jul 17, 2016 | Kenmore Washing Machines
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
HOW TO FIX O9 ERROR CODE?
F09: Machine Setup Error Found (AWD12)
Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
Dado
Sep 09, 2014 | Ariston Technologies Ariston AWD12 Front...
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more: http://forum.appliancepartspros.com/washer-repair/244131-error-code-f5-model-11045087404-kenmore-elite-residential-washer.html#ixzz34ySdUUeZ
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
Whirlpool awd/42115 user manual download
You can do yo THIS LINK and download the user manual in your choice of languages. Just type in the model number AWO/D 42115 in where it says, Commercial Code and click Download and it will start for you.
Hope this helps.
Jul 08, 2011 | Ariston Technologies AWD120WH Ariston
I have the error code 5 on the Ariston washer dryer combo AWD 121 what does it mean
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
Jun 07, 2010 | Ariston Technologies AWD121WH
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Open Questions:
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
