My 8.5 kg Defy top loader only wash at 30 not 60 what can I do...
Posted by Nandipha Saliso on
5 Related Answers
vest6
Elmer Vest
  • 196 Answers
SOURCE: Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Posted on Jan 12, 2008
Ian Greenland
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
robert samples
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 10, 2011
SOURCE: Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Posted on Feb 01, 2012
What is the e6 error code on a defy aqua wave top loader washing machine
Search for:
Make Model error code
or
check the troubleshooting section of the owner's manual
Jan 31, 2018 | Washing Machines
My defy top loader washing machine just overflow, the water enters without the machine been switched on and water does not stop entering even if I spin it
Could be a faulty fill valve. The inlet water pressure may be too high, making it necessary to turn off the water supply between wash sessions.
Jun 25, 2016 | Washing Machines
What load size is best on fuzzy wash, defy top loader
b safe with 8kg or try were u bought mech
Mar 02, 2015 | Washing Machines
Defy fuzzy top loader DTL139 has a EC error code
I need assistance with pressure switch e4 error
Jul 19, 2014 | Washing Machines
My defy daw 365 front loader washing machine won't start. The "end" indicating light stays on and the "door" light does not come on.
hi we just bought a second hand defy front loader washing maching can you please assist us how to use ot its Defy Daw 365 please
Feb 24, 2013 | Washing Machines
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
