Question about Home
Coromal 645 tow doors does it have shower and toilet and how many does it sleep
Posted by Bruce Dockrey on
I have a 4 section folding shower bath screen and need a replacement down rubber between the 3rd and 4th door please
if you can , take a section of the rubber you require to a shop that sells rubber products ( mats ,pools , mattresses rubber mouldings etc) as they have a range of rubber mouldings that may be suitable
try plumber wholesalers that sell baths , showers and toilets as they may be the agent for the manufacturer of the doors
Lastly the doors may be made by a glass fitter shop and they may have the rubber to suit the aluminium surrounds of the glass
Aug 06, 2016 | Home
Have to turn on shower for toilet to refill?
if you have had pluming don of late.. i think the connection to your toilet has been taken after the shower outlet..thud the tap on the shower is controlling the filling of your toilet..
Oct 06, 2013 | Eljer & Complete Toilet In A Box
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
My shower doors exploded while I am was sleeping! How will this be rectifie
Hi!you better change your shower door because its hard to rectifies that kind of door
Sep 25, 2011 | Kohler Home
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
114 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
