Question about Home
Coromal 645 how many does it sleep and do they have toilet and shower
Posted by Bruce Dockrey on
Toilet and shower runs great for a year> just had a sink hooked up and now toilet and shower back-up> was the sink hooked up wrong? to a vent or wrong pipe>
Nah, that doesn't sound like the toilet or sink were hooked up wrong, your sewage tank is probably full, you can have it pumped out for $100 or so. They fill up every so often for w/e reason.
May 01, 2016 | Saniflo 002/005/007 Saniplus Toilet with...
Help me locate a leak in the bathroom
need to check connections going to shower. turn on water and see if runs down lines. also try to reach up to the sink connections a do the same. they tend to come loose. should be able to hand tighten. also check behind toilet at connection.
Oct 08, 2014 | Jayco 2011 Greyhawk 31 SS
How to install toilet plumbing
This is not possible. The drain is much smaller from a shower . The feaces would get stuck
Jan 10, 2014 | Home
Have to turn on shower for toilet to refill?
if you have had pluming don of late.. i think the connection to your toilet has been taken after the shower outlet..thud the tap on the shower is controlling the filling of your toilet..
Oct 06, 2013 | Eljer & Complete Toilet In A Box
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
Shower gets hotter or colder when toilet is flushed.
This is typical for an installation without a balanced valve/anti-scald valve on the shower.
If you are using manual on/off valves on the shower, about the only way to fix this is to install the device mentioned in the previous paragraph.
May 03, 2009 | Rheem Tankless Hot Water Heater...
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
110 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
