Repair Erreur code E000674-0020 IR C 2380i - Office Equipment & Supplies
Posted by KINI Zama on
Terry
  • Office Equip... Master
  • 11,377 Answers
How to resolve erreur code E000051-0000
This is a side registration error.
Most likely the motor has failed, the small gear cracks.
This is the part you need.
FH6-1253-000
May 16, 2015 | Canon IR 2800 Digital Copier RECONDITIONED
Codes erreur photocopieur ir 1600
What model sir/mam?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 23, 2014 | Minolta Office Equipment & Supplies
Canon ir 2318 shwos "out of toner.I unpacked the
this is the common problem with 2318. u have to take out the developer assembly out and if u are a rep then check the toner shutter in the dev assembly.it some times does not move in accordance with the toner cartridge. u have to align it with cartridge in home position. and be sure to check the toner cartridge sometimes the churner in the cartridge is broken but 90% is the above said
Jun 03, 2011 | Canon Office Equipment & Supplies
Code erreur system E246 E354 canon IR1600 problem:
CANON IR 1600 ERR CODE 354 IT CAME AFTER REPLACING
MAIN BOARD HOW CAN I CORRECT THIS PROBLEM
Dec 27, 2010 | Office Equipment & Supplies
Error code E000025-0003 on canon IRC 2380i
I have canon coper IRC2380 appears code 000025-0003 ...plz help me
Nov 15, 2010 | Office Equipment & Supplies
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
jasbo
jasbo
Marvin
Marvin
