Godrej front load Wm e11 error showing in washing time
Posted by PIYUSH MAHAJAN on
5 Related Answers
Dov Dror
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
Anonymous
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
Anonymous
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
Anonymous
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Ac voltage become hihg or low when start ifb washing machine
Dear, Sir in my IFB Washing...i got a Ac Lo error hiw i fix this Error washing stopped plez give reply sir
Sep 30, 2012 | IFB Washing Machines
Error code e11
if its a frigidaire front load washer then code e11 indicates thats its a slow fill water problem,remove your hot and cold inlet water hoses and check the hose screens for blockage
May 31, 2012 | Washing Machines
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Jan 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
