Getting error message -9927 on Image class D530. Won't scan
Posted by Daniel West on
5 Related Answers
Anonymous
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
Anonymous
SOURCE: error message wrong cartridge
its not a true fix but I had the same issue. I turned off printer and slightly moved the paper thickness lever over a few inches. I turned it back on and the cartridge error was off. I do get a pop up from my printer program on the computer every time I initiate a print job asking to correct the lever, I click OK and it prints. I know its aRube Goldberg fix but I need this printer every day for work and for now it works.
Posted on Aug 11, 2009
Anonymous
  • 70 Answers
SOURCE: having error messages during canning, error
I think you did scanning directly from your printer, you should scan from the computer, just go to my computer and look for your scanner. Then you can scan whatever you wanted to.
Posted on Sep 29, 2009
canontech
Canon tech CROATIA
  • 1219 Answers
SOURCE: Canon Image Class D860 - Error message E003. How
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Posted on Jun 30, 2010
elix0411
Jose Cada
  • 3530 Answers
SOURCE: I have a Canon Image
Welcome to Fixya
Sound like there is a problem with the DC controller. The DC Controller supplies the proper voltage to the high voltage power supply pca. You must replace the DC controller board. You might need to take the printer to manufcturer's repair center if still in waranty.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Dec 17, 2010
Imageclass d530 error code e100 0001
Hi, tahta erro indicates a malfunction in the laser unit, probably dirty or defective
Jun 11, 2014 | Canon imageCLASS MF5770 All-In-One Laser...
Hitting F8 key repeatedly will not access Safe Mode option for my HP D530
If you getting this error then you won't be able to open computer in safe mood, Because this error message indicate that there is no proper bootable media selected or there is no OS in your Hard drive.
First thing you can do is go to BIOS and check what is your First boot device selected, if it is other then Hard drive then change it Hard drive and save setting and come out of it.
If there is any media, like Pen drive or any CD then remove it and start your computer.
If still you have same problem then I am afraid that your OS is Corrupted.
Aug 20, 2012 | HP Compaq d530 CMT Intel Desktop PC -...
MY PRINTER CANON IMAGE CLASS D611 NO PRINTTING DE
Hello and Welcome to FixYa!
Sir/Ma'am kindly explain your query, Is your printer shows some error message or it just prints blank pages without any error message? Before the problem started have you replaced your Cartridge or something you did? Kindly give some detail about the problem you are facing. I will help you according to that.
I am here for your help. Waiting of your response.
Thanks
Dec 04, 2011 | Canon imageCLASS D661 Digital Printer
I was given a Compaq d530 cmt and it won't boot says non-system disk or disk error hoe can I install unbunto on it as a spare
Download Ubunto onto a disc (as an image) and then you will need to boot to the disc in order to begin the installation process. With HP computers (including Compaqs), right after the computer is turned on, press F12 to bring up the units boot menu. Select the optical drive and then start the installation.
Jun 14, 2011 | Computers & Internet
I have a Dell Latitude D530 and the drivers for the Hi Def Audio Bus will not install
byronforeman
If you are having trouble installing the drivers most likely you do not have the right driver for the version of Windos you are running.
Let me know the version of Windows you are running and the error message that you are getting when you try to install the drivers.
Issken
Mar 17, 2010 | Dell Latitude D530 Notebook
Having error messages during canning, error
Sep 29, 2009 | HP Deskjet F4100 All-In-One InkJet Printer
''Bad Image'' Error?
First download a copy of Dr. Web, Malware Bytes and Superantispyware. Run these one at time. This should get rid of all your problems, if not a Windows repair is next.
Mar 29, 2009 | Computers & Internet
HP D530 CDRW problems
HI there
If u hav an old system try using lower cdrw 4x probably.
Jun 27, 2008 | HP Compaq d530 SFF PC Desktop
60 people viewed this question
Ekse
Marvin
Marvin
