Question about Kenmore Dryers
I need toget a heating coil for my sears kenmore dryer model no 970-C880870 serial no 4D20204600. I ALSO WOULD LIKE TO KNOW HOW TO GET TO THE COIL IN MY APPLIANCE TO G CHANGE THE SAME
Posted by ZULFI on
5 Related Answers
Anonymous
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
Anonymous
  • 88 Answers
SOURCE: need to instructions on how to stack a kenmore
to stack you will need the stacking kit. It can be order through Sears Parts/Product Repair Service department.
Posted on Sep 23, 2009
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: need to know how to change heating coil in white
The link below discusses disassembly of models similar to yours. The main difference is that the manual covers models with front controls whereas yours has top controls.
Unplug dryer. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Continue with "Removing the drum" on page 69. Having removed the drum exposes the heater behind it and safety thermostats above the heater shroud. The heater is generally purchased and replaced as a coil only not as a complete assembly as described in step 4 of page 72. Look for a break in the coil by touching all sections until found. If the break is not found check thermostats, motor switch at back of motor and heat contacts in timer for open circuits. Repair as necessary.
Reverse above process to reassemble.
Dryer Service Manual
Posted on Oct 01, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
Kenmore elite 110.629442100 parts diagram
model number doesn't come up but you can go here,put in your model number and see parts,sears.com
http://www.searspartsdirect.com/partsdirect/part-model/110.629442100
Nov 09, 2013 | Kenmore Elite He5T Dryer Heating Element...
MY DRYER WHICH I BOUGHT IN 2009 NO LONGER HEATS UP SINCE ABOUT 8MONTHS AGO! MODEL#110.69422801 SERIAL#MY3088080 TYPE=d433-ele-2406026-fm54
Hi vmalugin1129...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Jul 09, 2011 | Kenmore Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
My Kenmore Elite dryer is not heating up. Is there a coil that I can change? If so where is the coil located?
Check the heater element and thermal fuses for continuety.
Go to Sears.com and enter you dryer model, then go to parts description, enter heater, and from that you can go to the diagram of where the elemnt is.
Mar 16, 2010 | Kenmore 62602 Electric Dryer
Substitute heating element
Go to the local appliance repair parts store- they will have generic replacement elements and will likely be able to get you a right one for your dryer.
You should know if possible two things: model/serial number for your unit and length of the heating coil. (perhaps you've already taken it out)
Dec 14, 2009 | Dryers
Need to know how much heating coil cost on my 70 series kenmore extra capacity dryer.
open dryer door and get model # 3 numbers a period and 6 more #s, they varry in price from $30.00 to $100.00
Dec 09, 2009 | Kenmore Dryers
Dryer not heating on any setting.
Check to make sure you are getting full 220 Volt power to the dryer if you are then:
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
Reason for kenmore dryer model # 96520100 serial # MD2309364 not heating belt appears in tack and has new vent hose.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Good Luck,
Hope this helps
Oct 11, 2009 | Kenmore Dryers
Kenmore gas dryer after 5 to 10 min. later no more heat
My Kenmore 80 series (model 11072802100) has the same problem that it fires up first and then stop producing heat after a few minutes. It's also 7 years old. After a while, if I restart it, it will run and do the same thing. I found a thread of discussion on another forum that says that this can be the gas valve coil (solenoids) problem as these coils turn on and off the gas flow to the chamber. I'm going to check out the coils, but don't know where they are located (can't find the manual). If anyone has any idea, please share. Or I'll just tear off the top and back to see where they are.
Any gurus here to help? Thanks.
Oct 10, 2008 | Kenmore 72802 Gas Dryer
Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
185 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
