Question about Smith Corona Office Equipment & Supplies
I have a Smith Corona electronic typewriter. I got it a year ago and the keys worked, except the characters wouldn't show up. I replaced the ribbon, but now the keys won't work at all. What's wrong?
The carriage also won't go back automatically when it reaches the end. It worked before when I got it.
3 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Posted on Oct 29, 2007
typewritrman
Michael Frazier
  • 32 Answers
SOURCE: Hi,
Is the ribbon selector lever located on the right side of the keyboard switched to either red or black? If it's on white, the ribbon doesn't come up.
Michael
Posted on Jan 21, 2010
Testimonial: "Thanks a lot - that did it!"
Dick O Reilly
  • 3594 Answers
SOURCE: My Smith corona typewriter types the wrong characters.
Check to see if you are in KBII or a language mode if not look for bent or broken spokes on the printwheel.
DickyO
Posted on Apr 07, 2012
How to change ribbon of my Smith corona clipper typewriter
Hi Claire, The link below is a short youtube video on how to change a 1960s smith corona type writer.. Also you can click any link on the right side showing the same with other smith corona models, I hope this helps...
https://www.youtube.com/watch?v=PSTmerh6s6M
Mar 30, 2016 | Smith Corona Office Equipment & Supplies
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
I have Smith-Corona MarkI typewriter I need to know ribbon cartridge number.
I don't show a MARKI. If it is a Mark II it takes The "H" series ribbon General Ribbon # T309.
DickyO
Sep 13, 2011 | Smith Corona Office Equipment & Supplies
Need a ribbon for my typewriter(smith corona 30 years 0ld)
If you have the old spools your best bet is to wrap a new ribbon onto the spools.
DickyO
Aug 05, 2011 | Smith Corona Wordsmith 100 Typewriter
Hi, I have a 1967 Smith Corona Corsair portable typewriter with case. All works fine except that the ribbon does not lift when keys hit the paper. So the keys end up hitting the paper directly (not through...
Michael
Jan 11, 2010 | Office Equipment & Supplies
Smith Corona PWP 4002 fails to type,. need to know if ribbon is correctly installed as well as circular disk. Thanks
Did you buy an OEM or COMPATIBLE ribbon? If you bought a compatible, please make sure you have bought the correct design for your typewriter. Some compatible ribbons come with a lug that prevents them from sitting correctly.
I note that you posted this problem over a month ago. If you haven't solved the problem by now, i would advise you to contact www.inkribbonpaper.co.uk. I have used them a number of times with great success for our smith corona, brother and royal typewriters
Nov 23, 2009 | Smith Corona Office Equipment & Supplies
NEED OWNERS MANUAL FOR A SMITH CORONA PWP 3850
Try Will Repair Service for a manual.
(Click on "Will Repair Service" above to go to the manual web page.)
Best of luck!
Feb 18, 2009 | Smith Corona Wordsmith 200 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
Fitting new ribbons to smith corona 100 electric typewriter
Oct 28, 2007 | Smith Corona Wordsmith 100 Typewriter
47 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
