Question about Samsung Refrigerators
Control panel on rf26x Samsung refrigerator stopped working
If voltage to panel bad board if no voltage to panel bad transformer
Posted by Sandra Broach on
5 Related Answers
Anonymous
SOURCE: control panel not working Samsung refrigerator
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Posted on Jul 26, 2009
tauruscalugu
  • 9 Answers
SOURCE: i got a samsung refrigerator model rs2534ww
Sounds like you just need to do a reset, press and hold the top 2 buttons till it flashes then let go. If you hold it to long it will run a diagnostic mode and may lock up on the blinking light again. The blinking light is a trouble indicator for the service tech. It tells them that sensor or heater is faulty or will point them in the right direction. I found a repair manual on the online auction place E b a y that can help you troubleshoot further but have not bought it as of yet. I just purchased my Samsung and was reading some reviews to see what kind of problems i may run in to.
Posted on Jan 29, 2011
Matthew Cross
  • 88 Answers
SOURCE: Samsung RF26X series refrigerator. Power Co
This is normal after power outage .
Unplug for 30 seconds to clear code then wait several hours for computer to stabilize.Then your good to go.
Was this helpful?
Posted on Aug 16, 2011
Jay Kullmann
SOURCE: refrigerator control panel
88-89 Flashing Reverse 9.
I noticed this occurs when the Ice Machine get jammed up.
Remove all ICE from Tray and Clean.
Press and Hold Energy Save+Alarm Button for 10 Sec.
Posted on Sep 10, 2012
richroth
Richard Roth
  • 9472 Answers
SOURCE: The ice dispensing flap on my RF26X Samsung refer.
What is the complete model number?
Posted on Sep 01, 2013
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
Do transformers go bad on RP2100 heaters
if voltage coming in and connected correctly and fuses ok then check transformer voltage see inside front panel
Sep 24, 2012 | Raypak Pool & Spa
Carrier ac light on board out
High voltage goes to board then to transformer. 24v comes out transformer into board. Check high voltage going to transformer if have votage but no low voltage out other side 24v then transformer is bad.
Aug 28, 2012 | Carrier Heating & Cooling
Carrier fernace light on board not comming on
check high voltage going to board and transformer then check low voltage from transformer to board. If you have voltage on these board is bad. Correct voltage that is.high 110v-120v low 24v-28v
Refrigerators Logo
124 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
