Question about Sharp Televison & Video
I have a Sharp LC- 50LB261U. Based off videos I almost 100% that my TV needs a new LED driver. When does a TV also require LED strip replacement? Would only part of the TV show up if it did? Just wondering before I buy a LED driver. The screen is black, but I can see the menu with the flashlight test. Thanks for any help.
Posted by Joseph McCain on
1 Related Answer
Larry
  • 2800 Answers
SOURCE:
Going to need more information to help much, what do the various power board rails look like?...are they all good?
Going by the fact this set has had a lot of main board failures I'd lean towards that board but its just a guess without knowing some voltage measurements
Posted on Mar 11, 2018
The screen shows the lock mark and has changed color and can not change any sitting and we don’t have remote control
HCDZ Replacement Remote Control For Sharp LC-70LE732U LC ...
https://www.amazon.ca/HCDZ-Replacement-LC-70LE732U-LC...LC.../B00F3ZFA6QHCDZ Replacement Remote Control For Sharp LC-70LE732U LC-46LE830U LC-70LE733U LC-80LE632U Smart AQUOS PLASMA LCD LED HDTV TV: Amazon.ca: Electronics.
You need a remote, but just try disconnecting it from the mains. That might get rid of the lock symbol. The blue hue is a fault and you need a television engineer or a new television.
Mar 18, 2018 | Televison & Video
My sharp tv LC-42LE540U is very dark on the bottom half of screen what is my problem
You may have some burned out LED strips that make the back light for the screen.
Mar 07, 2018 | Sharp Televison & Video
My Sharp LC-50LB261U tv screen went black but i still have sound. i replaced t-con board and power supply board and have same problem. can you help?
I don't have a service manual for that set so I'm only able to help on a limited basis...Have you tried the flashlight test?...if the backlights are out then it could be a backlight driver board if it has one? or defective LEDs. See what you have for voltage going into the panel LED's
Oct 18, 2017 | Sharp Televison & Video
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Televison & Video Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
