Question about KitchenAid Dishwashers
Kitchen aid dishwasher Model KUDG25SHWH1 leaks after putting in new seals
5 Related Answers
Anonymous
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Posted on Nov 13, 2008
Anonymous
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
Anonymous
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Kitchen aid dishwasher-how do I stop water from leaking from the bottam of the door when it is running?
the sealing rubber known as th "membrane" might be worn out. if you have a while using the dishwasher. if its still under warranty do not touch it just notify the retailer where you bought it from.
Dec 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Kitchen Aid model#KUDS25SHBL1 and it leaks through the bottom of the door. What is the cause and how do I fix it?
There are two things that could cause this issue. The first and most common is a cracked feed tube. The feed tube is the plastic pipe that sits under the upper rack and feeds water to the middle spray arm. If this tube breaks or cracks it shoots water directly down toward the front of the door and leaks occur. The part number for a new tube is 3378144
The second thing it could be is the lower door seal, it clips onto the inner door liner at the bottom. It is part number4172127
Jul 13, 2010 | KitchenAid 24 in. KUDS02FR Built-in...
The new dishwasher kitchen aid we bought is leaking
If it is leaking from the front, then there is a problem with the seal that runs around the front of the dishwasher. It is usually located behind the main door on the edges of the unit itself, it will look similar to weather stripping. A cheap way of fixing this is to get real good weather stripping from Wal-Mart, Home Depot, Lowes, etc. It will have a sticky surface on one side, you peel off the paper, then apply the weather stripping to the actaul door, first try to mark where the old one sits against it.If its leaking from underneath, than it can be a number of things, but most are easy to repair, you just have to pull the dishwasher completely out to get a better look. Sometimes one of the components will be leaking, but for the most part, it might just need a new hose clamp or tightened up. Hope this helps.
Dec 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a kitchen aide dishwasher ~ only about 6 yrs old ~ and it's the higher end model with the Wood panels , anyway , Its leaking water on the bottom ~ Is that the main seal ? and How hard is it to...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | KitchenAid Dishwashers
The rinse aid despencer is leaking
You might look into getting a new cap. It seems like part of the problem is that the threads on the cap or dispenser are damaged. This will cause the seal to not work correctly and thus leak the rinse aid.
Jul 03, 2009 | Whirlpool Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Dishwasher leaks, is there a recall on this model,mdb7100awb
if the dishwasher is leaking water there is no recall on that. the recall i believe you are talking about would be for the rinse aide leaking in the door. you should contact maytag to see about getting the new kit installed on your dishwasher and you may get your leak fixed for free since the kit comes with the door seal.
You can contact maytag at (800) 675-0535 do not wait and do not use the dishwasher. you will need the model number and serial number off your machine when you call. it is located near the door seal on the tub.
Jan 03, 2009 | Maytag MDB7100AWB Dishwasher
Rinse aid leaks into the dishwasher when the door is closed
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishwashers Logo
166 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
