Hi Ola, check that the connection cable is ok or replace it with another cable
check with another phone if the line is ok
Indicate the brand and model of the phone you are commenting on, in order to find the best possible solution
Hola Ola, comprueba que el cable de conexion se encuentre bien o reemplazalo con otro cable
comprueba con otro telefono si esta bien la linea
indica marca y modelo del telefono que estas comentando, para poder encontrar la mejor soluci?n posible
Posted on Aug 20, 2019
Testimonial: "Pañasonic KX-TGC350. This is Ola"
Well Ola, check what I tell you,
Keep in mind the distance of the hand phone, with respect to the base, if you have many walls to cross, it is very possible that you have no signal for that reason, do the tests in the place where the base is located
If you have no results, go to the store that bought the phone and claim
regards
Bien Ola, revisa lo que te indique,
ten en cuenta la distancia del telefono de mano, respecto a la base, si tienes muchas paredes que atravesar, es muy posible que no tengas se?al por ese motivo, haz las pruebas en el lugar que se encuentra la base
Si no tienes resultados, ve al comercio que compraste el tel?fono y reclama
Saludos
SOURCE: PHONE JUST A DIAL TONE?
Make sure your phone is in Tone and not Pulse dialing. To change it for your phone, just look in your manual. If you don't have one, I have included a link for you to d/l it.
Manual
Posted on Jan 20, 2008
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
SOURCE: phone has not dial tone or buttons have no function
my phone rings when someone calls, when i pick up the receiver to answer the phone is dead. i have an old phone i plug in and it works fine. we had a prolong power outage, and was wondering if it might have an effect on the phone.
Posted on Feb 06, 2009
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
Jun 01, 2015 | Lands Phones
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
Jan 18, 2014 | Northwest Bell Nw Bell Wht Corded - Big...
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
May 28, 2009 | Uniden Cordless Phone
Mar 18, 2009 | Panasonic KX-TG5632 Phone
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Sep 29, 2007 | Uniden Cordless Phone
124 people viewed this question
