Question about Sharp Televison & Video
Will a fire stick work with Sharp 50"LED LC-50LB150U?
Posted by Nedd Ross on
Ed Cole
    Habit-Forming:
    New Friend:
  • 123 Answers
Will work on any tv with HDMI input
Posted on Sep 02, 2019
1 Related Answer
ronald hapin
  • 16 Answers
SOURCE: LC-42DH77E Sharp No picture Green led comes on
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Posted on Apr 30, 2011
Sharp LC-70LE733U won't turn on, remote or the power button? I was able to enter service mode and then test the TV it works fine.
After enter in Service mode press Ch down & Vol Down from LED back panel.
Select 8/10 page by pressing up & down button from remote
Select EEP , Press Ok button from remote
EEP - will show running
Switch off LED from main's and restart your LED will work properly.
Jun 08, 2017 | Sharp Televison & Video
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
Sharp aquos will not turn on
The Power controll board is likely bad.
Dec 29, 2014 | Sharp AQUOS LC-50LE440U 50" LED TV...
No satellite connection anymore
Hi Andrea
Please contact the authorized service center. Do not do any researches, or experiments with this set. OK?
Gopakumar Gopalan Google
Mar 12, 2014 | Sharp LC50LE440 AQUOS 50" 1080p LED TV...
Sharp Auquos TV randomly reboots itself
Had to put my 50 inch in shop after having it for only 6 weeks. Sharp's needs to replace the main board which is on back order from Sharp. I don't know when I will get my television back.
Oct 15, 2013 | Sharp LC-50LE650U 50" 1080p 120Hz AQUOS...
LC-65D93U Sharp LCD not powering up just the blue light blinking
Our experience solving this was fairly long and I hope FixYa will excuse me for posting a link to it rather than copying all of it.
It's a free share of our experience and some hints on troubleshooting Sharp LC-65D93U with blinking power LED.
Of course your problem may be different, but the know-how we gained and share should still be of help in your quest:
http://blog.coppelltvrepair.com/2014/06/sharp-lc-65d93u-blinking-blue-led.html
Hope it helps!
Jul 05, 2011 | Sharp LC-65D93U Television
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
