Question about Health & Beauty
Lights flash 4 times on a hoveround mvp5
Went down a ramp at bottom chair started to swivel around to left and then lights flash 4 time
Posted by Thomas Hancock on
Ed PeeBee
    New Friend:
  • 42 Answers
According to manual. (https://www.hoveround.com/Hoveround/media/Document-Library/D82008753R-MPV5-Owners-Manual.pdf)
4 flashes: The right hand motor has a bad connection.
Other codes...
New VSI Controller 1 flash: The battery needs charging or there is a bad connection to the battery. Try charging the battery. 2 flashes: The left hand motor has a bad connection. 3 flashes: The left hand motor has a short circuit to a battery connection. 4 flashes: The right hand motor has a bad connection. 5 flashes: The right hand motor has a short circuit to a battery connection. 7 flashes: A joystick fault is indicted. Make sure that the joystick is in the center position before switching on the controller. 8 flashes: A controller fault is indicated. 9 flashes: Problem with the brake circuit. Check that the manual release levers are in the drive position. 10 flashes: An excessive voltage has been applied to the controller. This is usually caused by a poor battery connection. Speed Bar Cycling: Controller locked. Speed Gauge Cycling: Check if battery charger is still connected to controller or controller fault.
Posted on Aug 19, 2019
5 Related Answers
Anonymous
  • 205 Answers
SOURCE: My hoveround MPV5 will not operate. fully charged
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 15, 2009
Anonymous
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
Anonymous
SOURCE: Trying to set time on nike watch
1. Press the bottom left button(MODE) to put on Time mode.
2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
5. Press the LIGHT button to finish.
Posted on Apr 06, 2010
Anonymous
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Posted on May 18, 2010
Testimonial: "That was the problem, Thanks !!!"
dennis bullard
  • 4090 Answers
SOURCE: Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
How do I remove the seat to replace the batteries. My seat is swivel.This a Hoveround mobility chair
Hi most scooter's & chairs u pull on you're seat swivel lever & at the same time lift the seat .::::
some chairs had a small lever u have to push
located on the seat stem under the seat ..
cheers
Jul 08, 2018 | The Health & Beauty
Tip
How to Diagnose Trouble Lights on Hoveround Power Wheel Chairs
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
on Oct 05, 2010 | NRS Hoveround MPV 5 - Used Power...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
How do you get the seat too swival on my mvp-4 hoveround power chair
Hoveround manual:
Took the answer right from the manual. If you would like a digital copy of the manual, the link is posted below.
[The swivel seat permits the seat to pivot from the forward facing position through 90 degrees in either the left or right directions. The seat will lock in each of the forward, left and right facing positions. This feature is provided to make side transferring easier. The swivel release lever is mounted on the left side in the standard
position]
http://www.hoveround.com/.../MPV4-Power-Chair-Manual.pdf
May 21, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Hoveround chair only turns left
Do the casters swivel? If not, make them loose.
Are the tires properly inflated? If not, inflate them.
Does the silver post part of the joystick move up and down at all (if it does it's shot)
Has it been exposed to outside moisture? If so your motor brake may be ceased and needs to be disassembled and cleaned.
Hope this helped.
Oct 21, 2013 | Hoveround MPV5 Electric Wheelchair - Used...
Hello, changed a flat tire on hoverround and when i went to turn on to go....the lights were flashing on the left arm rest area?
Check the freewheel lever in the front of your chair If it is freewheel then thats the cause of the lights flashing other than that you don't give too much more info to be able to answer your problem Hope this helps
Mar 28, 2011 | NRS Hoveround MPV 5 - Used Power...
When I press the Run button, the Battery Level lights flash on and off rapidly (all at once, 2 or 3 times per second) and I get a beep-beep error signal. I had just used the chair a few minutes before and...
To diagnose the problem, I need to know how many bars are flashing. If the power chair was jsut working and now it is not, you may have accidentally knocked a manual brake lever out of position with your heel. Take a look at this website to find out what the flashing lights may indicate is wrong with your power chair.
Oct 09, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Im getting a mvp5 tomorrow and is it safe to keep powerchair in minivan when its hot outside?
Would you keep your cellphone, laptop computer or other expensive electronic device inside a closed car in the summer heat? If yes, then your power chair should be fine. If you feel the heat is too intense for other electronic items, then it is too hot for the Hoveround. A few hours may not be bad, but extended storage in extreme heat may cause damage that may void your warranty.
Jul 10, 2010 | NRS Hoveround MPV 5 - Used Power...
How do I charge the Hoveround mpv 4? I plugged the charger into the chair and plugged the cord into the wall using an extension cord. The red light on the box turns red when in the "on" position but the...
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Jun 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
