Document feeder feeds are crooked. On a household Brother Printer/Scanner (DCP 7065DN).
I've tried wiping/cleaning the feeder rollers with alcohol and generally cleaned around. Consistently skews all pages in the same direction about 5 degrees.
Posted by The GreyOne on
  • The GreyOne
    The GreyOne Aug 21, 2019
    Hi... thanks for the guess. I should have explained more. Printouts are OK when just the copier is used whether if the originals are on the flatbed OR in the document feeder. The SAVED IMAGES of the SCAN process of the same originals were about 3° clockwise... multiple pages. I actually a search on the Brother site found a hit for someone with the same problem but only on a similar printer. I was able to figure out how to do it on my printer and it WORKED. https://help.brother-usa.com/app/answers...
303 Electronics
  • Office Equip... Master
  • 345 Answers
A few things can cause that to happen.
1. Make sure the toner is sitting correctly all the way in the drum unit.
2. Make sure the drum/toner are inserted all the way into the printer.
3. Check that the printer's back door is closed fully.
4. Open the back door and check if there is anything in the way of the paper.
5. Make sure the width set guides are not broken in the printer tray and are set correctly.
Posted on Aug 19, 2019
Testimonial: "If the toner isn't seated correctly and if the back door is open, most printers will sense that and won't even start trying. The other things I'd checked already before asking the question. But thanks for the advice anyway."
  • 303 Electronics
    303 Electronics Aug 19, 2019
  • The GreyOne
    The GreyOne Sep 08, 2019
    Not the feeder. If I put a "good" straight original even on the flatbed... a printout is straight but a scan comes out crooked. Totally unbelievable... but the link to a Brother site that I left. above WORKED ???
    But thanks for the try...
Micheal Chipperfield
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 14 Answers
One of the rollers could be jammed with a staple or small bit of paper?
Posted on Sep 08, 2019
Testimonial: "Sorry Micheal... if you'd re-read my comments you'll see that it couldn't be the feeder... that I'd found a solution that seems to be some sort of software reset for the Scanner."
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Brother DCP8020
Left hinge is broken.
Posted on Dec 12, 2007
checkitright
CheckitRight
  • 1363 Answers
SOURCE: Brother MFC 8440 Scanner has a line
Whoaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!!!!!!!! No need to da all that. Lift up the Doc feeder and look at the SMALL strip of glass, you will see a dot or something on it, clean w/alcohol. Voila taken care of. the dot ( pen mark, white out, etc...) makes a line because the document is Moving and that dot now looks like a line to the copier. :)
Posted on Sep 26, 2008
Anonymous
  • 24 Answers
SOURCE: Automatic document feeder doesn't wotk.
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
894
Posted on Mar 02, 2009
Anonymous
  • 48 Answers
SOURCE: The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Posted on May 25, 2009
Gerrit Jan
  • 217 Answers
SOURCE: hp 3015 auto feed
You'll have to replace the feedroller kit. Partnumber CB414-67918. Gerrit Jan
Posted on Nov 05, 2009
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
How to configure Brother DCP-7065DN to scan directly to Synology DS412+
I don't believe the DCP-7065DN allows scan to FTP. Brother's models MFC-7460DN and MFC-7860DW do provide this function. Good luck and please share your solution should you find one.
Dec 31, 2013 | Brother DCP-7065DN MFC / All-In-One Up to...
Brother dcp 7040 prints grey film over the page
someone cheaped out and got the el cheapo paper.
The low quality paper has paper dust on every page....
when the printer feeds this cheap paper thru the machine it drops the dust onto the tonor cartridge rollers and causes the roller to accumulate toner on the roller... this in turn is transfered to the pages being printed.
check your machines operation manual. There may be a clean cycle you can try to run to clean the rollers...
I had to buy a new toner cartridge for mine when this happened.
Apr 17, 2013 | Brother DCP-7040 Laser Multifunction...
How do you clean rollers on manual feeder
To clean the rollers or separator pad
1. Remove all originals from the document feeder tray.
2. Lift the automatic document feeder cover (1).
This provides easy access to the rollers (2) and separator pad (3), as shown below.
1 Automatic document feeder cover
2 Rollers
3 Separator pad
3. Lightly dampen a clean lint-free cloth with distilled water, then squeeze any excess
liquid from the cloth.
4. Use the damp cloth to wipe any residue off the rollers or separator pad.
NOTE: If the residue does not come off using distilled water, try using
isopropyl (rubbing) alcohol.
5. Close the cover of the automatic document feeder.8_29_2012_4_02_48_pm.jpg
Aug 29, 2012 | Dell 1135n AllInOne Laser Printer
Document does not feed
Pull up to open the document feeder. Clean rollers and pad with alcohol.
Jun 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Scan with feeder, cuts off the bottom of the document
Hello sir; You may use rubbing alcohol to clean up allthe rollers at document feed unit, it will take care the problem.
Feb 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Dec 20, 2008 | Brother MFC-8840D All-In-One Laser Printer
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
52 people viewed this question
Ekse
Marvin
Marvin
