Question about The Office Equipment & Supplies
The power head to my central vaccum does not work. Cannot find a reset button. Has only been used 2-3 times.
Posted by Beverly Wagner on
Robert Oliver
    Sergeant:
  • 323 Answers
Might be operating perfectly, but the drive belt may be broken.?
Posted on Sep 03, 2019
1 Related Answer
vacman66
  • 26 Answers
SOURCE: electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Posted on Jul 06, 2010
Power head motor dose not operate when switch on handle of vaccum
Its possible if the head is belt driven that it has clogged with fibres or could even have snapped. Unplug the vac, turn it over and have a look, you may need to remove a cover plate first.
Oct 20, 2014 | Vacuums
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
Error Number 5200 Printer Error has occurred contact the service center
How Reset Canon PIXMA error 5200: The printer is turned off and plugged the power cord. Press the button STOP / RESET and hold, then press and hold the POWER button. POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Release both buttons simultaneously. Press the power button, then the printer will off Press the power button again, then the printer will be lit and ready for use.
If this does not solve the problem, here is another method:
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working.
May 03, 2011 | Canon Office Equipment & Supplies
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
My Canon MP270 printer shows the following error 5200 P08
P08 (Print head temperature rise error) : 6. P08 (Print head temperature rise error): thermalprint head temperature exceeds a threshold.
Replace the new cartridge print head and / or change a new logic board.
Jan 12, 2011 | Office Equipment & Supplies
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
Electrolux central vaccum works sporadically
Jun 09, 2010 | Electrolux Central Vacuum
Mp160
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
1. try to take out colour ink and then put in again to see ok or no
2.try to install new cartridge to see ok or no
3.try cleaning head just go to printer preferences go to find services and click clean head.
4.if this all can't is better you send you printer to authorized canon to check you printer is print head problem or no....
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement
Sep 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dyson animal
called dyson they told me to turn the vaccum on and off 5 times, lower the handle to the floor when it was off. Now try the vaccum again and it worked. This is somekind of reset.
Thanks Paul
Jan 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Central vaccum
If the outlets work on the 2nd story ok, and not on the 1st floor, then you may have a wire that has come loose. There maybe a junction that split off between the 1st and 2nd floor. I assume you are talking about the suction and not the brush roll on the power head. If it is the power head not working, then check where the 2 prongs go into the outlets to make sure that the plug receptacle haven't gotten pushed in from the holder.
May 30, 2007 | Windsor SR12 Sensor Bagged Upright Vacuum
29 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
