Question about Danby DFF8802 Top Freezer Refrigerator
Where is the defrost timer located on a Danby model DFF8802
Posted by Frank aleardi on
David Spradling
    Top Expert:
  • Danby Master
  • 11,320 Answers
Should be behind back panel inside freezer
Posted on Aug 22, 2019
5 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
Anonymous
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
Woody J Hiatt
  • 306 Answers
SOURCE: maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Posted on Aug 22, 2009
DANBY REFRIGERATOR MODEL NUMBER DFF092C1BSLDB WHERE IS THE DEFROST SENSOR LOCATED
The defrost thermostat is going to be behind the rear panel in the freezer and on top of the evaporator there's no picture but you can talk to Danby parts dealers I'm posting a link below to the page that is related to your refrigerator and its parts it come in helpful
Danby DFF092C1WDB Refrigerator 9 20 Cu Ft
Appliance 911 Sea Breeze
If you have any other questions please let me know I'll try to answer them for you. The people that sell the parts call this a defrost protector just for your information
Sep 09, 2016 | Danby Refrigerators
Change defrost thermostat on model dff9102w
Danby, has recall on defrost timer . please try that on ,if still you like to change defrost thermostat open the back cover in freezer you can seeit
Nov 07, 2014 | Danby DFF9102W Mid-Size Refrigerator White
Freezer is cold enough but refrigerator doesn't get to temp. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 12, 2011 | Danby DFF8802 Top Freezer Refrigerator
We have an older model Danby D730, it is freezing on the back part inside of the fridge. We realize there is no more around, is there anything that we can do to save it.
Sounds like defrost problem. Could be fan motor, Defrost timer,or defrost heater. Try turning off for 8hr to melt ice then turn back on.If it runs and maintains temp for 24hr check and repair defrost Problem.
Sep 06, 2010 | Danby 11.4 cu. ft. Frost Free Generation...
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Defroster comes on every time fridge starts running. Make: Danby Diplomat
Defrost timer may be bad stays on all time try pulling one wire off the timer and see if it starts without defrost on
Jul 16, 2010 | Danby Refrigerators
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Open Questions:
Danby DFF8802 Top Freezer Refrigerator Logo
145 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
