L5 ERROR - TREDMILL STARTS OK BUT AFTER A MINUTE AND A HALF IT STOPS WITH L5 APPEARING ON SCREEN. WHAT DOES THIS MEAN?
Posted by PIETRA sMIT on
4 Related Answers
frannyjunk
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
Anonymous
  • 6 Answers
SOURCE: After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Posted on Jul 29, 2009
mlkary
  • 31 Answers
SOURCE: after 10minutes the tredmill stops
The walk belt is either worn out causing too much friction on the deck which overheats the motor or there is a lack of lubricant between the walkbelt and deck. Do not use silicone or unapproved lubricants as they will deteriorate the walkbelt.
Posted on Jan 16, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: KENMORE CALYPSO WASHING MACHINE
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Error E07 on Carl Lewis Treadmill
does any1 know how to fix the e07 error on the carl lewis tredmill or why is has appeared?
Feb 06, 2011 | Sport & Outdoor - Others
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
Jul 11, 2009 | Bowflex Treadclimber
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Jan 26, 2009 | Washing Machines
System error
Look for a reset function in camera manual If no manual download one - if nada, then contact Nikon customer service for inside assistance with dilemma. Due to high cost of camera repairs you just might have to go shopping.
Aug 26, 2017 | Nikon COOLPIX L5 Digital Camera
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
