Question about Music
Tryint to repair a 1960s ge radio tuner string found a few videos and none match what i have in front of me its a ge modle number t1250a
Posted by James huber on
Steve Cox
    Master:
  • 674 Answers
This is not a musical instrument - it is a radio. Try the radio museum online.
Posted on Sep 30, 2019
1 Related Answer
psycodelek
John Ziehm
  • 206 Answers
SOURCE: I found a 1960s vintage villager 12 string in a pawn shop asking price 260.00 did i find a diamond in the rough?
if its in playable condition with no stress issues a fender villager could be worth between $450 and $1500
Posted on Jan 29, 2015
Testimonial: "John thanks so much ..you have know Idea Im at least going to buy it I have a sence about these things its a pawn shop I found by accident while working in the neighborhood I new it was special when I saw it thx again"
How old is my piano?
no way for us to know or find out .
Jan 04, 2016 | Music
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
Jan 28, 2015 | Music
How to tune 12 string acoustic with ga40
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
The nut on my neck feel off how do i put it back on so i can addjust it
I am not sure if you know what the "nut" is... it is the little bar that the strings go over after they leave the tuners. If this is what you are refering to, the "nut" just rest at the end of the fret board and is held in place by string tension. You orient it so the one flat side goes down and rests on the neck and the other flat side rests agains the fret board end. You USUALLY do not adjust this unless the string height is wrong at the end of the neck nearest the tuners. Essentially you just seat it and then the string tension holds it in place... The only adjustment available is to lower it by taking material off by sanding OR to put a few layers of parchment paper beneath it.
Hopefully this is the nut you are talking about and not the truss rod adjustment which, unless you are experienced, you should NOT attempt to change. If you have disturbed the truss rod, take it to a guitar shop for repair.
Sep 11, 2011 | Washburn Festival Series EA20SDL Cutaway...
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Jan 05, 2010 | Music
My tele tuners have a slot in the tuners. I am
Usually you have either loops or little metal spools in loops at the end of the strings. The little spools are put down into the slots to secure the strings. If your old strings have the spools, you can remove them and put into your new strings.
Sep 29, 2009 | Fender '72 Tele Deluxe Electric Guitar
My sx prob is with intonation, I set it up with the tuner on the 12th fret etc, but when I think I'm done I play a few chords and D or A is out. Also my G string is almost way back into the bridge with...
If you have a floating bridge such as a flloyd rose you will have this problem unless you followed the instructions for changing strings. The instructions are on the net for various manufacturers. Ibanez, BC Rich and flloyd rose all have good instructions. There are other good sites to explain bridge and intonation adjustments. You have to remember that new strings have to stretch in before they can be tuned accurately. My son has a Jemm that he does one string at a time and lets them sit. You also have to take string guage into account. Different guages tune differently especially if you are mixing the guages. http://www.fretnotguitarrepair.com/Electric_Guitar_Intonation.htm is a good place to start. Hope this helps.
Jul 16, 2009 | Music
LP epiphone 100 "g" string problem,
after tuning ....put a capo on ... if this stops the problem then the cause must either be
1 the string catching in the top nut or
2 a faulty machine head
if it still goes out of tune with the capo on then look at where the ball end of the string sits
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
Music Logo
145 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
