Gas cook top makes clicking sound
SOURCE: Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
SOURCE: Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
SOURCE: Maytag MGC5430 cook top range IGNITION KEEPS
This sounds like a burner switch.There is one under every knob there are two wires going into them. i think the part number is 7403P367-60.
SOURCE: i was cleanning my 24" stainless gas cook top when
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
