Question about Kwikset Locks & Locksmithing
Kwikset 913 light does not blink red
My v913 helicopter took a little crash to the front and now my controller wont connect to my helly the red light on the helly used to blink to link up but now it just stays solid red
sorry Kyle but you're going to need a new circuit board for that the 913 it crashed and must have cracked or something so you can have to change hair a circuit board
Jan 03, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
Replaced batteries, now I am getting 3 sets of 2 loud beeps everytime I unlock the door with either code. Also the green light is continuously blinking.
The troubleshooting instructions (link here)
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HifLAAS.aspx
will tell you that you will get a series of quick beeps when the batteries are installed correctly and making good contact.Conversely, the low battery indicator light on the power board will be lit when the batteries need replacement. Kwikset recommends that you use four quality alkaline AA batteries.
Also, Kwikset recommends that if your Powerbolt is beeping, that you take out the batteries and remove the powerstrip. Let it sit for one minute, then put the batteries back in and wait for another minute. If it does not beep, as in above for battery replacement, then the keypad needs to be replaced. If the unit beeps, then the powerboard needs to be replaced.
Is it at all possible that, when you replaced the batteries, you did not get the orientation correct for one or more of the batteries? Did you use new, brand-name alkaline batteries?
So, I've taken you through the steps that a Customer Service Rep is going to ask you before you make a call. If the problem still persists, then it's time to make that call. The number is 800 327-5625, Mon.-Sat. between 7:30-4:00. Pacific coast time. They should be able to assist you further with troubleshooting and parts.
Good luck-and please provide feedback if this helps!
Dec 15, 2011 | Kwikset UltraMax Powerbolt 1000
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Green light keeps blinking even after changing batteries
I can't help you directly, but I can direct you to Kwikset's customer service contacts. I'm sure they can assist you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
There is an 800 number to call listed here.
Jul 21, 2011 | Kwikset 909 909-L03 Lifetime Polished...
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
I installed the lock about two years ago. The lock is still woking but has the red light flashing. what couldthe problem be?
The red LED indicates a low battery. here is a link to replace it:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Feb 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The light continues to blink
LED light goes red (not blinking, just stays red) and none of the buttons on the lock work.
My reply:
Jan 08, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do i program this remote for sharp tv, i need the code
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required.
SHARP 002 013 014 111 502 712 812 813 913 918
Oct 11, 2009 | Philips Universal PH301S Remote Control
Locks & Locksmithing Logo
195 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
