Question about The Office Equipment & Supplies
How to remove the tray model v745a
How to remove the removable tray from model V745A
Posted by Merrily Smith on
Chris Walker
    Top Expert:
  • The Master
  • 1,551 Answers
5 Related Answers
Anonymous
SOURCE: Can you tell me what filter the Vicks Warm Mist
did you figure out the filter? there is a filter there when you take it apart but it doesn't say anything in the manuel about changing a filter. let me know if you figured it out. thanks
Posted on Mar 07, 2010
Anonymous
SOURCE: v745a water valve does not
the value would have been stuck inside the white cap, so when you press the stick with the spring, the head of the valve should stick out. If this does not work, just remove the spring and the black stick from the value, water should come out
Posted on Dec 13, 2010
Rich Landrum
  • 4736 Answers
SOURCE: I recently bought a Vicks
If you still have your Owner's Manual or Guide, it should tell you where and how to order replacement parts. Or it should have a Customer Service telephone number you can call.
Posted on Apr 01, 2011
Randy Mayfield
SOURCE: can't remove all that scale
I took mine apart and poured CLR solution (Calcium Lime Rust remover) in the tray until the heating element was covered. Let it sit for several hours. If some scale is still there, use an old toothbrush to rub over the heating element (don't use anything abrasive). Rinse well and reassemble the unit.
Posted on Jan 07, 2013
jkhbewtrgwe
Brad
SOURCE: Water tank broken V745A Vicks Humidifier
I think you can find another one on amazon, take a look: Amazon com v745a tank. I hope this was helpful. Have a nice day
Posted on Dec 16, 2014
Where can i get a new water tank valve cap for vicks model V745A?
Best option might be to drop an email to the supplier of the humidifier Kaz at [email protected]
You can download the manual from this site in case it is any help.
http://s3.amazonaws.com/szmanuals/8a7c1db00996618dffc2e2382335c08c
Aug 02, 2014 | Vicks Warm Mist V745A 1 Gallon Humidifier
Can't remove all that scale on this v745a humidifier. thanks
Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and let it sit for 30 minutes, Then start the humidifier and let it run until almost all of the solution has been used. Turn the unit OFF, empty the remaining solution and fill the tank with Bottles Distilled Water. Turn the unit ON and run for 30 minutes. This will flush out any of the remaining solution. The remaining water should be disposed of and in the future, use Bottled Distilled Water, rather than tap water. That way you will not have to worry about calcium and mineral build up at all. Plus, the mist that's generated will be totally void of any harmful minerals.
Hope this helped you solve the cleaning issue. Please let me know. Thanks!
Apr 19, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
I recently bought a Vicks warm air humidifier with model V745A and the tank broke where can we order a new one
Apr 01, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
V745a water valve does not work (will not allow water through), only have unit 2 months
Dec 09, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Can you tell me what filter the Vicks Warm Mist V745A 1 Gallon Humidifier takes?
Mar 06, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Jun 21, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
Cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
May 23, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
81 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
