Question about Boss Music
Boss micro BR --> I have it plugged into my recording keyboard and the 'LIN' doesn't seem to pick up sound after it's plugged in. 'MIC' feature seems to be working. Thanks!
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: I need help with my Boss Micro BR. I want to
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Posted on Oct 13, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I have boss micro br hooked up to my computer it
You won't find a specific Micro Br Icon since it is a data transfer connection only.
Try going to "My computer" and it should appear similar to when you plug in a USB stick. It MIGHT have a meaningful name, but it might not.
Posted on Dec 26, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: how do i connect active speakers to a BOSS br 1600
I would come out of the line out jacks on the studio into the line in jacks on the speakers. Make sure both ends of the cables have the correct plugs on them. I'll include a link in case you don't have the correct manual:http://www.alesis.com/content1023
Posted on Mar 27, 2010
Fred Yearian
  • 5603 Answers
SOURCE: just bought Kingston 2GB SD Card for Boss Micro BR
This is likely a compatibility issue. Turn power off and remove the card and make sure the unit comes back to life.
SD card compatibility can be a problem.
You might want to go to VSPLANET.com as there is a lot of info on forums about recorders.
Posted on Jun 04, 2010
Testimonial: "Great stuff.Thanx for the info"
Anonymous
  • 9 Answers
SOURCE: Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
The beats you have programmed into the drum machine will not play through the midi cable. In order to do what you want you need to connect the audio output from the drum machine to the audio input of the br-1180. What you should then do is connect the MIDI out of the the br1180 to the midi in of the Dr5. This will allow you to start and stop the drum machine with the play button on the br1180. MIDI can be a complicated thing so be sure to RTFM about MIDI for both of your BOSS devices to understand what they can do to work together. Good Luck
Posted on Dec 14, 2010
How do i factory reset Boss Micro BR Digital Recorder
I know how to set it back to factory boss micro br.
Mar 18, 2012 | Boss Micro BR Digital Recorder
Trying to record using the onboard mic in mp3 mode. I get drive or disk busy - Ok
Generate a new audio file to record your project. If that does not work try to reboot your recorder. Also try an external mic.
Feb 21, 2010 | Boss Micro BR Digital Recorder
When I record with the internal mic or the BA
I had that problem too. What you need to check is the input level on the right side. Turn the wheel all the way up to 100 and the internal mic should be fine.
Feb 07, 2010 | Boss Micro BR Digital Recorder
How do i transfer music from my Computer to my
Page 2 of the Turbostart manual explains that in some versions of Windows the Micro BR may appear as a removable storage device titled "Removable disk (?:)." The manual is here:http://cms.rolandus.com/assets/media/pdf/MICROBRts.pdf It also mentions free downloadable wave converter software. Hope this helps.
Jan 28, 2010 | Boss Micro BR Digital Recorder
My micro br got wet. when i discovered this it had fixed on hold. I dried it out for a day and it seemed to be working fine but a couple of days later now and all the displays seem to be fine but there is...
I am sure it can be repaired. Whenever ANY electronics get wet, IMMEDIATELY remove ANY pwer sources, including internal batteries.
If wetting was not pure water, flush unit with de-ionized water till absolutely clean of any residue. shake out all water and allow to dry a week before applying power.
Jan 25, 2010 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Dec 02, 2017 | Boss Micro BR Digital Recorder
Music Logo
Top Boss Music Experts
Mosaub Al Masri
Mosaub Al Masri
JonSnell Electronic
JonSnell Electronic
daniel
Level 1 Expert
Are you a Boss Music Expert? Answer questions, earn points and help others
