Question about Viking Kitchen Ranges
Where is the spark module located on my dual oven Viking professional range
    Top Expert:
  • Viking Master
  • 1,533 Answers
Posted on Aug 18, 2019
Anonymous
SOURCE:
Anonymous
SOURCE: cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
Posted on Dec 22, 2007
Anonymous
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
Anonymous
SOURCE: Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
Anonymous
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
Anonymous
  • 67 Answers
SOURCE: Viking professional Range Thermostat problem
Try www.retrevo.com/s/Viking-Range-VGIC305-4B-Ranges-review-manual/id/6768ag911/t/1-2/ . . .Good luck
Posted on Jul 30, 2009
I have a Viking 48 6 Burner, Grill Professional Series Dual Fuel Range - VDSC485-6Q Dual Fuel Oven. When I try to use both ovens at the same time they shut off.
Have you got the correct supply to it for both ovens to operate? You'd be best off having it looked at by a service engineer, as they can carry out all the relevant checkers to ensure the gas and electric are adequate for the kw rating of your appliance
May 20, 2018 | Viking Kitchen Ranges
Oven shuts down
they both use 220 and , you have to put it on different breaker , that can handel 32 amps.
Feb 26, 2014 | Viking 48" 6 Burner, Griddle Professional...
Takes forever for my oven to preheat to 400*. 25 minutes or so. Oven is brand new.
A brand new oven should work. You should not tinker with a brand new oven. A brand new oven that is malfunctioning is probably under warranty and should be repaired under that warranty.
Viking is the Rolls Royce of kitchen equipment. Call your installer or builder or Viking for service for your brand new oven.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Viking Professional VGSC3666BSS (Dual...
Viking Oven Not Working After Self-Cleaning
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 15, 2010 | Viking Professional VGRC365-4GD Stainless...
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Viking dual-fuel range ignition problem
You may have wet it somehow. There are two fixes. Leave them on for 20 minutes on high to let the ignitors dry out. If they dry and stop clicking you have solved it. If not then contact Viking 888-845-4641 and purchase a 6 point spark module. You can try to replace this yourself. With the power OFF. Remove the wires one by one placing them on the new module and then attaching it to the wall. (this is if ur spark module is located under the burners.) If it is in the rear of the unit and u can pull out your range yourself without hurting yourself then you do the same thing. Good luck. If none helps you you may need to replace all 6 burner bases or ignotrs. Also easy. Good luck.
Mar 24, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Kitchen Ranges Logo
75 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
