What is the name of a device that uses a control knob to set the level of something
Posted by asanda on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Televison & ... Master
  • 35,852 Answers
Variable resistor
Posted on Aug 18, 2019
One for All urc6810. What is code for something?
Something? What is it? Strange indeed!!!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 13, 2016 | Televison & Video
I have followed instructions and used code for Panasonic tv and it's not working do I have to have my TV set to something
Try different codes said for Panasonic brand. This is a trial and error procedure. It might take some time. You have to check it with different set-up codes, and should choose, one which give you maximum functionality to your device with remote control.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 12, 2015 | Panasonic Televison & Video
What does manufacturer control auxiliary input auxiliary output mean
set level of input and output for audio .. similar to line in and line out of a stereo amplifier. This means you cannot alter the level of the signal out put or input to your audio system. It is set by the manufacturer. For a 1996 Ciera I assume you are adding some type of interface so you can either input or output a signal for a device. It is probably a set level on the interface. Some interfaces have tiny knobs where you can control the gain for input or output orthers are set by the manufacturer of the interface.
Aug 03, 2015 | 1996 Oldsmobile Cutlass Ciera
My ps3 head set has said paired but not working , why . this 2 one ive got same problem.
The headset only works for games that support headset communication.
With that in mind, after you successfully pair a Bluetooth headset with your PS3, you need to verify that it's currently being used by the system.
- - - - - - - - - Skip this section if you've paired the headset already - - - - - - - -
To verify that the headset is paired, go to:
XMB (main menu) > Settings (second icon from the left) > Manage Bluetooth Devices (5th icon down) > [name of your Bluetooth headset] under Device Name with a blue dot next to it
-If you don't see your headset under there, select "Register New Device" on the bottom of the screen and follow the prompt
-If you see the device name, but the dot to the left of the device name is black and not blue, turn on your headset and on your PS3, highlight the headset device name and press the Triangle button and select "Connect"
Finally, to verify that your headset is being used by the system, go to:
XMB > Settings > Audio Device Settings (7th icon down)
From here, make sure that the Input Device shows the name of your headset's device name- if not, highlight Input Device and press Up and Down on your controller to select the headset.
Next, you will do the same thing for Output Device- select your headset device name if it is not shown.
Once your device name shows in both Input and Output Device areas, you can talk into the headset and you should be able to hear yourself. Adjust the microphone volume by changing the number next to "Microphone Level". The bars on the top of the screen in Audio Device Settings should move and respond to speaking into the microphone.
Finish by selecting OK on the bottom of the screen to save your settings. Don't hit the Circle button or else the changes may not save!
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I bought a used xbox 360 and it says to save a game I need to make a profile,but when I try to create a profile it says I need a storage device... for all the $$ this thing costs it has NO internal memory...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.......
Click here to download repair guide
Dec 24, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Input level too high can't seem to make lower
Have you tried the setting in your computer for sound sources. Some have audio level controls. If you still can't get it low I would use pot, wire it accros the audio output from the deck then to the source.
I'm adding an image of a stereo potentiometer below which also shows how to connect it. You can get a box to mount it and some rca sockets to connect the two devices. You just need a knob. You then just turn the knob to get the right level.
Dec 01, 2010 | ION Audio TTUSB05 Turntable
How can I hook up my ipod to the Mackie 1604-VLZ PRO? I'm not sure which control buttons, knobs or slides to use to to make it play. I plugged it into the "tape in (RCA)" jacks. I need help with the...
Easiest is to use a 1/8 inch stereo to 1/4 inch splitter cable (1/4 mono's) and plug into the tape input. Then use the tape level knob.
IF you want to use sliders, then plug the spliter 1/4 inch plugs into two channels and set the PAN controls for these to opposite ends and then you have to adjust two sliders to control the gain.
Sep 05, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
My subwoofer on my philips 5.1 speaker system is constantly generating lots of bass noise even on mute.
I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
Jul 07, 2009 | Audio Players & Recorders
Can not set device input level in system preferences for MAC
That's correct. There's no other input volume control besides the analog knobs on the front.
The level's still too low with the knob turned to max? What are you trying to record?
Feb 01, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
NUVI 250W compared to the C330 streetpilot
Are both units set to the same level of detail in the map options?
It is possible to choose the level of detail displayed on the maps. Look at your map settings in the setup menu to increase the map detail.
The level of detail may also be different if both models are not set to the same map scale. The more you zoom in, the more detail you see.
Nov 01, 2007 | Garmin StreetPilot C330 GPS Receiver
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
