SOURCE: I have had salt in for 3 weeks culligan mark 89 is not recharging
i have a 1997 mark 89 culligan, the softener is not softening the water i ran a manual recharge and nothing. i can hear a noise coming from it all the time, like a grinding or clicking, but doesnt sound like water going thru it unless i hit manual charge. can you email me with answer [email protected] have taken triangle metal thing off top and cleaned screen and tube
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
SOURCE: o-rings leak on a culligan mark 50 water conditioner
Neither a manual or parts are available for this this valve. It is obsolete.
RJ
SOURCE: water has been trickling to the drain
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
SOURCE: Need a manual for a culligan mark 89 water
Here is a the link for the MK 89 Use and Care Guide
http://www.isingsculligan.com/manuals/Mark89-812%287-97%2900881597.pdf
If you are looking for a parts manual that may be almost impossible as they are very protected.
RJ
