Question about Tablets & eReaders
My craig CMP801-BUN tablet crashed after trying to install a windows 10 update for version 1803. what is the fix?
The windows start button on the tablet no longer works to shut down or restart or navigate to any files. the only icon that opens is the recycle bin.
Posted by Joseph Foster on
  • Anonymous Nov 11, 2021
    My ICRAIG model CMP801-BUN windows wireless touch screen tablet will turn on but it will only show a black gray screen none of the app/recycle bin will work. IDK what to do it does say on the back to use a USB jack to charge the battery i will try that if it does not work Idk what else to do pls help me with this I tried doing the reset in different ways but yea...
Chris Walker
    Top Expert:
  • 1,551 Answers
Posted on Aug 18, 2019
5 Related Answers
ChipcircuiT
Jorico Berongoy
  • 157 Answers
SOURCE: My Dell Inspirion 1501 taskbar icons are turning white
scan your laptop...check with a good antivirus...
scan.................................
Posted on Jan 06, 2009
Anonymous
  • 227 Answers
SOURCE: Windows Vista Ultimate: Recycle Bin
If you find that when your Recycle Bin does not refresh but shows the same icon, irrespective of whether it is empty or full, here are some trouble-shooting steps you can try. Hopefully, one of these 5, should help you. 1) Check if you have installed any Theme or an Icon Package, and see if uninstalling it makes the problem go away. if so then the problem is in the Theme or Package. Also try switching the theme to Windows Classic theme and them back to Vista Aero default. 2) Right-click Desktop > Personalize > Change desktop icons > Disable / Uncheck Recycle Bin. Then click Restore Defaults. Click OK. Reboot. Now using the same method Enable /Check Recycle Bin, then restore defaults. Click OK. Refresh Desktop. 3) In the 'Desktop Icons settings' Dialog Box, check on Recycle Bin.
Then click on the ‘Recycle Bin Empty’ icon.
Click on 'Change Icon' tab.
rom the new box which opens, select the icon that shows the 'Recycle Bin Full'.
Do the same for 'Recycle Bin Full' icon.
Change it to 'Recycle Bin Empty' icon.
Now click Apply.
Now check whether, when the Recycle Bin is full, the empty-icon show. And vice versa.
If it does, go back and again change back the icons, to what they should be, using the same procedure, mentioned above. 4) Use the Group Policy Object Editor.
Type gpedit.msc in Vista's Start Menu Search bar and hit enter.
User Configuration > Administrative Templates > Desktop > Remove Recycle Bin icon from desktop > Double click on it > Enable > Apply Reboot.
Next, follow the same above-mentioned steps. But this time instead of 'Enable' select 'Not Configured.
See if it helps. 5) Repair or Re-build the Icon Cache. For this the easiest way would be to download and use TuneUp Utilities or Stardocks Icon Packager. They are not freeware, but you can use the trial versions to get your job done.
Posted on Apr 04, 2009
Anonymous
SOURCE: installed new update to fix freezing problem - created new one
I had the same problem. Mine originally stopped at 23/92 files. Then after a cool night, I started it again in the morning and got 91/92 files loaded before it started to fail again. I left the disk in and after about 20 fails in a row, it finally loaded!!! Recommend you just leave it in there and it should work. good luck
Posted on Apr 26, 2009
SOURCE: Cant see desktop icons or access Windows anymore. Brand new Nc10.
If the Windows loading progress bar appears after turning ON the Computer and the Computer goes to the blank screen then perform the under given steps.
Press "CTRL+Shift+ESC" key combination to open the Task Manager window.
Next, click on the "Applications" tab and click on the "New Task...." tab located on the bottom of the window.
Then type "explorer.exe" and click "OK".
This would bring you back the Desktop icons and the taskbar.
Posted on Sep 15, 2009
Rinoo Kumari
  • 2973 Answers
SOURCE: Wacom Tablet Installation: Where's the Setup Process?
What you should do now is to go to Control Panel->Add Remove programs. Select the entry for this tablet and delete it. after disconnecting the tablet reboot the PC. Then without connecting the tablet, install the drivers, Reboot. Connect the tablet and allow Windows to detect the tablet and load its drivers. Then only will work properly.
Posted on Nov 20, 2009
How do I upgrade my Craig tablet to 4.4?
You presumably mean versions of Android operating system.
I went in to this a while ago owning a couple of little used but old tablets and now many of the apps no longer work and can't be updated.
I read an article by a boffin who had tried to update Android. He got inside the structure of Android and after much fiddling around he made it better so it would accept a few updated apps but most of the important ones still wouldn't go.
The reason for this is Android is as unlike the Windows OS as it is possible to get. Tablet and phone manufacturers buy a current version of Android and then they have to modify it to make it work with their electronics and that makes their version almost unique. Updates have to come from that source. Some manufacturers provide updates but many don't and when it has outlasted it's usefulness it is time to replace it with a newer unit. If update is in the menu it will have a longer useful life but lots of label engineered units and budget models don't have that option meaning the "manufacturer" has no intention of providing updates.
The boffin concluded for all practical purposes there is no way to load a later version of Android onto older electronics.
Need to reset a digiland dl808w tablet NO TOUCHSCREEN
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
How do I update my CRAIG Tablet?
Did you set up your tablet for wifi reception? do you have a home network tfrom where your tablet can get connection?
I have a Craig 7 inch touch screen tablet it comes on but doesn't load
Dear Craig User,
I understand your delima with this tab, however unfortunately this product doesn't carry a very good market reputation.
For the kind of issue you are facing, I would recommend a reset (Hard reset) for which you may follow the following procedure.
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Post your update, let us know if it helped.
Regards,
Sid
I have a Craig 7" Touch Screen CMP741e with Android. I have attempted many times to get it to reset to factory mode but with no progress. When I turn it on, it is stuck with the Android logo. I can no
You need to reload the firmware. There are two different versions of the CMP741e - the one you have is the newer one with the GT811 touch screen. You need http://www.craigelectronics.com/firmware_update/android4.0/cmp741e_firmware4.0_cleaner.rar for that model. Follow the instructions for the firmware update on the Craig website.
1helpful
How do I install google play service
http://theunlockr.com/2012/10/29/how-to-root-and-install-google-apps-on-the-craig-cmp741d-android-tablet/
Gmail app crashes on Mini iPad. A restart of the app and the iPad did not solve the problem.
Make sure you have the latest version of the Gmail app. There was a version a month or two ago that crashed a lot, but the update fixed that.
3helpful
2answers
Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
10helpful
3answers
How to hard reset Craig 7 inch touchscreen tablet model cmp741e
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
