Hi im clueless to setting up tv my husband handled this stuff he has passed .. so my cable is off I have a SUNSUI FLAT SCREEN TV I THINK ITS 32 in does anyone know if its smart TV or do I need a converter box and antennae to watch TV. I read instruction book not help ful ahhh help please
Posted by Kelly decarsky on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 32,322 Answers
Sorry to hear about your husband Kelly, I am twice a widower :>(
A Smart Television always has a button on the remote with something like 'smarthub' on a button. Also the back will have a socket for a network cable which looks like a big telephone cable. This is to connect it to an internet router, or cable box.
You can see the details on the television if you search Google for
make model specs.
You need some sort of converter box for cable, satellite, or even an over air telephone signal. In a condo, you just have a socket for an aerial cable.
Posted on Aug 17, 2019
5 Related Answers
Anonymous
SOURCE: protron flat 32' tv with broke screen need to replace
The screen to my protron 32" broke can this be replaced
Posted on Jun 23, 2008
Anonymous
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
Posted on Nov 09, 2008
Anonymous
  • 93 Answers
SOURCE: GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Posted on Nov 11, 2008
Anonymous
  • 3 Answers
SOURCE: Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Posted on Feb 18, 2009
Anonymous
SOURCE: Converter box turns off by itself when watching tv.
Check the settings in the menu--many boxes have "power save" mode and will shut off after anywhere from 2-12 hours of inactivity. You should be able disable it or change it to a longer time.
Posted on Mar 14, 2009
We have a Plilips 32 pfl. We have been playing DVD's with this TV but we cannot watch it with the entire width of the screen. When we watch our HDTV cable, it views the entire screen but not the (non-HD)...
Of course its possible! You can use either your tv remote or your cable remote. On the cable remote it is usually the # sign, hd zoom, or stretch.
If you use your tv remote go into your menu and look for your setup or settings. Go to the picture option and select pass through or auto adjust.
You should be good to go after that:)
Nov 21, 2010 | Philips 42PF9431D/37 TV
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
Jul 09, 2010 | Sharp LC-32SB21U 32 in. LCD TV
When I hook my tv up to my desktop computer the screen looks like it is going to work (it says dell then the loading bar fills up) as a monitor until it is time for my log in screen to come up. The screen...
hi,
This is normally due to a frequency or resolution incompatibility. Turn on your desktop computer, then change the screen resolution to 800x600 or 1024x768. Save the settings. Reboot to check that it is indeed saved.
Once you boot up on your TV, it should display fine. Gradually increase the resolution and colors to the max your TV can handle.
Feb 28, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Hi, I have cablevision hooked up to my LTV-32 and I use the cable remote. Unfortunately,I have lost the original Westinghouse remote. I was pushing the volume button on the TV itself the other day,...
I would recommend investing $20 on a new Westinghouse original remote for your unit. The remote will cost you $15 and about $5 shipping and handling from [email protected], just make sure you let them know the model#, and serial# and the request for a remote, once you have the remote you should be able to play a bit more with the TV and get to the original settings. If you have any questions or need some more assistance just email me at [email protected]
Jan 15, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Music on DVDs is louder than the dialogue.
In the Audio set up menu, see if there is a setting to turn off surround sound. I believe it's in your owners manual also. LMK
Feb 28, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Tv monitor won't turn on
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Apr 22, 2008 | Televison & Video
Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
Feb 10, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
