Question about Photography
SOURCE: the Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
Posted on Dec 28, 2008
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Posted on Sep 25, 2009
SOURCE: Pics from Computer to Pandigital
If you use iPhoto to put photos on the frame, you'll end up with a bunch of extra files on the frame that say "Unsupported Format". This is file management data added by iPhoto.
When you connect the frame via the USB cable, it should just appear as an icon labeled "Pandigital" on the desktop. You can just drag and drop your photos onto this icon.
Posted on Jan 23, 2010
SOURCE: pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Posted on Jul 13, 2010
Aug 21, 2017 | PANDIGITAL Cameras
Oct 30, 2013 | Kodak 4x6 Personal Photo and Negative...
Aug 24, 2011 | PANDIGITAL PhotoLink PANSCN06
Dec 26, 2010 | PANDIGITAL Panscn02 Photolink Scanner
Nov 02, 2010 | Computers & Internet
Jun 18, 2010 | PANDIGITAL Panscn02 Photolink Scanner
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Dec 31, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Jan 20, 2021 | Nikon Photography
150 people viewed this question
