The KCP&L power comp.changed the meter and I lost power and now the tv will not turn on
Posted by rodney butner on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 56,115 Answers
  • Open internal fuse
  • Power supply failure
Posted on Aug 18, 2019
Muz series led flashes twice
58 volts is not enough to run a compressor either your meter / reading is wrong and there should be no voltage on compressor terminals when disconnected .
Nov 22, 2014 | Heating & Cooling
Mitsubishi tv customer service
i have a blinking green light and then the red lamp light comes on and stays. no picture no sound
Aug 07, 2013 | Televison & Video
Zenith Z50PJ240 powers on and turns off relays click while its doing this unplugged ysus and zsus no change unplugged comp board tv turns on red light goes out but will not power down then.
It becomes first a case of checking voltages to and from power supply first and then a guessing game---which board will you buy and try first?
Nov 06, 2012 | Televison & Video
Models: KCT, KCP Power Switching device: Standard Open- Transition 30 to 4000 Amps Programmed- Transition 150 to 4000 Amps Electrical Controls: MPAC 1000 Problem: Power went off, generator Started,...
try to find the manual , these units have a pre program set from the factory, dissconect the unit at the generator 1)battery terminal 2)main switch on generator 3) reconnect battery and turn on the switch,press auto,should reset
Jun 09, 2011 | Kohler Electrical Supplies
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Power up then goes off
take your tv to a w/shop, it has variations at a power supply connect a avo meter and check for changes at the output of a supply.
i check capacitors change values
ii semi conductor lekages
Jan 26, 2009 | Zenith B25A02Z TV
Laptop's light is turning off!
This is going to be a problem with either the screen inverter, or the screen backlight. I would recommend have it diagnosed first to see which it is. You can test this yourself if you have an ohm meter, and a little technical know how.You will need to pull the screen bezel (the plastic piece around the front of the screen), the are screws hidden under the small round plastic sticky tabs on the bezel. Once you've removed the screws the bezel will snap off. Get it started at one side and work it up the rest of the way around, be careful not to break it ar the corners when lifting it off. Once the bezel is off you will see the inverter at the base of the screen. Power down the machine and disconnect the lead that goes to the screen. The power going into the inverter is very low, the inverter boosts the power back up to what the screen needs to work, so the power on the screen end will be significantly higher than the motherboard end. The voltage range differs machine to machine, so I can't tell you what it should be exactly, only that if it's the same or slightly higher from end to end, then it's bad. Now, inverters can be changed out, but backlight are part of the screen and cannot be change out. If it's a bad backlight, then the entire screen will need replaced.
Aug 22, 2008 | IBM ThinkPad R40 2897 Notebook
Lost signal
well overall the tv isn't too reliable but perhaps you have the input on comp(vga) if you do that it says no signal and shuts off, try changing the channel by click either the channel up or down button, or just press the input button.
that would be the easy fix, or your tv is just broken like so many others, myself included
Mar 21, 2008 | Polaroid FLM-1911 19 in. LCD Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
