Why did I loose some hd channels - Televison & Video
Posted by Melvina Pittman on
NOEL
    Top Expert:
  • Televison & ... Master
  • 8,546 Answers
Hi Melvina.
There could be a lot of reason why.
So go to this link and have a look on the page you might find something to help you find out why this could happen.
https://www.google.com/search?q=Why+did+I+loose+some+hd+channels&rlz=1C1AVFC_enGB797GB798&oq=Why+did+I+loose+some+hd+channels&aqs=chrome..69i57j33.511j0j8&sourceid=chrome&ie=UTF-8
Posted on Aug 17, 2019
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
Digital channels are not working
If your TV is connected to a "cable" box, e.g. you're using cable TV ... then it is the cable TV box that determines what you can get (based on your cable subscription). Yes, I know that some cable TV and satellite TV service providers will only deliver HD digital channels when you pay an additional (monthly) fee for HD digital channels.
If you plug the cable directly into your TV (i.e. not use the cable box), you may be able to do a channel scan on your TV, to pick up the digital channels ... but you will loose the convenience of using the features that your cable box provides .
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
How do you tune in to get freeview HD on the TXP42S21B
You simply need to perform the auto-setup when you first use the television. The freeview HD channels will tune in at the same time as the standard def. (SD) channels. You will find them in your channel list but there are only 3 freeview HD channels currently available - BBC HD (Channel 50), ITV1 HD (Channel 51) and Channel 4 HD (Channel 52).
If these channels are missing, it's may be because the HD broadcasts haven't started in your area yet. Please visit this page and enter your postcode to find out if you can get these channels:
http://www.freeview.co.uk/availability/
If you've gone past the auto-setup and you need information on how to tune your TV, please consult your manual or post back here and I will assist you.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | Panasonic Televison & Video
Describe your sylvania lc225ssx green screen Problem Screen goes green occasionally. Switching to an HD channel then back usually corrects for a while. Sometimes power-cycle also temp fix.
Whenever I hear "green screen" it is a loose or faulty HD cable(s).
Check your HD connections to make sure they are inserted fully and if there is no change, try an alternate cable.
Jun 17, 2010 | Sylvania LC225SSX LCD TV
HD channels look terrible
You may not have the resolution set to hd even though you are on the channel. Confirm that you are using hd cable and your set is displaying 720p or greater. This will sometimes pop up on the screen when you tune to a hd channel. it sounds like you are on 480 i or p. good luck
May 04, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a Visio GV42L HDTV loosing sound on some channels
That's a broadcast signal issue not TV issue. If it was the TV all channels would be the same.
Aug 21, 2017 | Televison & Video
Pixilization on non hd channels with hdmi cable connected to HDPVR receive. HD channels come in crystal clear, non hd channels are all bitmapped and horrible
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Nov 03, 2009 | LG 42LG30 42 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
