Robot coupe rc2b. Suddenly, there are no lights at all. When I plug it in, the green and red light usually come on--now nothing at all.
Posted by Elizabeth Zaenger on
5 Related Answers
Anonymous
SOURCE: Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Posted on Nov 09, 2007
Anonymous
SOURCE: 8525 Red Light
Take the battery out then plug in the phone. The light should turn red, then reinsert the battery with it still plugged in. It should turn orange and start charging.
Posted on Jun 27, 2008
Anonymous
  • 63 Answers
SOURCE: Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Posted on Aug 21, 2008
Anonymous
SOURCE: flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Posted on Mar 19, 2009
Anonymous
SOURCE: when i turn the tv on the light turns red rather than green when lite and the screen stays blank.
There is no power coming from the step down transformer
Posted on Jun 01, 2009
Robot coupe food processor RC2800 SN: R2579592 120v 6amp has no power at all, and power supply is good
You will need to find a "small appliance repair shop" in your area, most likely the main PCB has failed, it controls the motor. Check the yellow pages.
Aug 19, 2016 | Robot Coupe Food Processors
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Light flashes but won't turn on
The Roomba's internal charging system is not working. In this situation, a replacement Roomba is necessary. You can call 1-877-855-8593 to find out what your options are. There's a discount for Roomba owners who need replacement units.
Jul 22, 2009 | iRobot Roomba 560 Robotic Vacuum
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Roomba Schedular
Let it charge for a full 24, or even 48 hours, regardless of the green light. If it still dies you probably need a new battery.. or worse.
Aug 31, 2008 | Roomba Robotic Floor Bagless Vacuum
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
