Shaw satellite has changed their channels and switched them to new H.D. channels. We are having difficulty finding the new channels. Is there a quick reference guide or help with the new channels??
Posted by Derek smith on
john h
    Top Expert:
  • Televison & ... Master
  • 23,424 Answers
Notify shaw
Posted on Aug 17, 2019
5 Related Answers
dinomb
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Adding/deleting a new contact to the system directory
You can download the full phone manual from Panasonic here.
Posted on Mar 26, 2009
Anonymous
SOURCE: where to find quick guide of whirlpool AWZ 475
I have moved into an apartment with a whirlpool AWZ475 washing machine with no instructions. Is there somewhere I can get an operators instructions on line ?
Posted on Aug 05, 2009
Anonymous
SOURCE: Our Shaw cable box,Pace PVR,continously BLANKS out
I have had the same problem and I spoke to a tech at one of the tv repair shops in Edmonton. He says it is a long standing generic problem that Shaw is having with the HDMI connection between the pvr and tv's, I have a pvr replaced twice and the problem remains. The last Shaw tech says to use component cables and it will solve the problem which I believe is an admission that the problem identified by the tv tech is true. Doesn't help with 4 hdmi.and two component inputs
Posted on Mar 18, 2010
marked
Mark Gil
  • 6487 Answers
SOURCE: need owners manual
Here is the direct link for your manual
http://www8.garmin.com/manuals/StreetPilotc330_OwnersManual.pdf
Posted on Apr 23, 2010
Testimonial: "The results I received was great. Timely and exactly what I needed. Thanks"
I’m a Shaw customer and I’m moving to Cold Lake AB. I have purchased my Shaw box, for cable TV can I use it in Cold Lake AB. Is there Shaw in Cold Lake AB
yes there is
Search Results
Satellite TV Cold Lake, AB ' Shaw Direct
https://www.shawdirect.ca/order/alberta/satellite-tv-cold-lake Choose the satellite TV package in Cold Lake, AB that fits your lifestyle and budget. Get more options and more entertainment for less.
Shaw in Cold-Lake-AB ' YellowPages.ca™
https://www.yellowpages.ca > Canada > Alberta > Cold Lake Locate and compare Shaw in Cold-Lake-AB, Yellow Pages Local Listings. Find useful information, the address and the phone number of the local business you are looking for.
Shaw Cable in Cold Lake AB ' YellowPages.ca™
https://www.yellowpages.ca/search/si/1/Shaw+Cable/Cold+Lake+AB Locate and compare Shaw Cable in Cold Lake AB, Yellow Pages Local Listings. Find useful information, the address and the phone number of the local business you are looking for.
Cold Lake, AB Compare 16 Internet Providers ' FindInternet
https://www.findinternet.ca > Home > Search > Alberta Research and view all Internet providers in the Cold Lake area. Find all Internet options with accurate plans and pricing from Xplornet, TekSavvy Solutions Inc. and 14 other providers! Shaw in Cold Lake AB Google Search
Apr 21, 2018 | Televison & Video
We cannot change the channels
On the Shaw remote control, press the 'CBL' ("cable") button,
and then press the Channel-Up or Channel-Down buttons on the right-hand edge of the remote.
Got good batteries inside the remote control?
Oct 15, 2013 | shaw.ca
Www urcsupport com
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Sep 23, 2013 | Televison & Video
Want to know how to record from the small box to VHS
Connect the "output" cable from the Shaw Digital Terminal to the "video-in" on your VHS recorder. Change the channel on the VHS to channel #3. Then, press RECORD on the VHS controls.
Sep 20, 2013 | shaw.ca
Free samsung tv hook up diagrams
If you have the "basic" Shaw Digital Terminal, use the TV's remote to set the TV to channel 3. Use the Shaw Remote Control to "channel-up" and "channel-down".
Sep 03, 2013 | Audio Players & Recorders
How do we connect our system using a Shaw PVR
Do you have a optical/coaxial input on your system? Eg: cable, TV.I use a optical input on my Yamaha ( cable, satellite ). Look to see if there is a optical/coaxial output on your pvr, there should be. Use ether the optical or coaxial output from your pvr and connect it to the cable (satellite ) optical/coaxial input on your receiver. The manual that came with your Shaw PVR should explain how. You will get 5.1 surround if available on certain channels.I prefer optical over coaxial myself, but they both work well.If you don't have optical/coaxial inputs on your receiver, you will have to use RCA cables, analogue out on cable box, to tape input or aux on your receiver. You will not get surround sound, just stereo. But it's better than nothing.
Jan 18, 2013 | Onkyo Ht-rc330 5.1-channel Home Theater...
Vizio TV remote is in conflict with Shaw TV remote. When the TV is on, the Shaw bow and the shaw remote control would not work. I turn both systems off, then turn the box on with the remote, select a...
You need to "program" your Shaw remote to control your TV, including the volume up/down on the remote.
Mar 09, 2011 | Vizio M420VT 42 in. LCD HDTV
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
