Question about MK Battery Health & Beauty
Bought a new monster moto 250 battery .has23volts .turn switch on runs 5 seconds than stops why?
Posted by Maurice Laroche on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Posted on Nov 16, 2008
Anonymous
  • 12 Answers
SOURCE: Ds Lite Will not charge for longer than 5-10 seconds
It might be a defective battery. Try putting the new battery in a DS lite that you know works. If the other DS works with its own battery, but doesn't with with your battery, then your battery is most likely defective.
Or you could take the battery out of a good DS that turns on and can do everything, and put it in your DS. If your DS still doesn't work, even with the other DS's battery, then your DS might be broken.
Posted on Dec 19, 2008
wd4ity
wd4ity
  • 4565 Answers
SOURCE: Attempted to start , pushed start button , engine
Ok, make sure your battery is installed and connected correctly. The connections should be clean and tight. Now, look at the end of your starter. You'll see a five sided plate with a tower like thing in the middle on the end of your starter. Just above it is a single wire that plugs onto the starter. Unplug this wire and insert a test light into the wire. Turn your ignition on and press the start button. If the light lights up, your starter is bad. If it doesn, you've got another problem.
If the light does not light up, you'll have to find the starter relay. Harley moves these things around all the time so you never know where to look for one from year to year. I'd start under the seat and then move to the side panels if necessary. The relay is a typical one inch cube made of plastic. When you find it, turn on the igntion and press the start button while holding the relay. It should click. If if doesn't, it's probably bad and even if it does, it's probably bad. I'd replace the part as it's not all that expensive.
If you suspect the starter, go back and remove the three screws that hold the five sided plate onto the starter. Behind the plate you see a plunger with a spring on it. NOW, MAKE SURE THE TRANSMISSION IS OUT OF GEAR. Using a large screwdriver, push the plunger into the starter as far as it will go. The starter should engage and turn the engine. If not, you may have to replace the large copper contacts in the solenoid.
I hope this helps you find and fix your problem
Ride Safe
Steve
Posted on Jan 02, 2011
wrenchtec312
Hammer Time
  • 884 Answers
SOURCE: Blower motor on 1999 Buick Regal with climate
You need to first test for power and ground arriving at the motor to determine which one is missing and that will dictate your next test.
Posted on Aug 16, 2013
Richard Brooks
  • 242 Answers
SOURCE: 1986 yamaha 250 moto 4 , replaced battery +ignition switch I have no power to main head lamps , starter/ ignition switch and neutral / reverse lamps but engine wi start if bump started
Considering the year model it could easily be a faulty connection from loose or contaminated wiring.,relays.,Alternator..Save time and check rectifier/regulator before wiring nightmare...Start and run engine sitting still at 2000 rpm.for 1 minute..,Shut it off.Carefully touch regulator ...If it is Extremely hot it is your problem.If not take it to mechanic..I would save time and troubleshooting nightmares because wiring will drive you crazy If you know nothing about it..Take to a Motorcycle Tech and let him repair it correctly ...Then he will explain the problem
Posted on Apr 05, 2015
Keeps defaulting to pause every 5 seconds
1) replace the batteries, and clean the contacts batteries with c. cleaner
2) adjust the REED switch, see the diagram attached, clean it and tight the connector very well.
3) tight the ribbon cable very well inside, and clean it with c. cleaner with carefully.
God bless you
Sep 09, 2012 | Schwinn 250 Recumbent Bike
I have a mercedes 2004 ml270 and the central locking doesn,t work. If you sit in the car and press the lock button on the console then all doors lock but i can,t get it working on the key fob. Have tried a...
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment.
Feb 14, 2010 | 2004 Mercedes-Benz Mercedes Benz M Class
I have a fully charged battery and even bought a new one and the monster truck goes strong for 20 seconds and then just stops but makes a high pitched noise. If you lift the truck up and use the remote it...
hi, the problem your having is with the motor.
Their is no way to fix the motor the only option you have is to go to a rc shop and buy a new motor.
The good news is you can by an upgraded moto witch will make your car faster their a many parts you can upgrade so my advice would be get yourself down to a local rc shop look on the net or your phone book for one then give them a visit. you will be surprised at the things you can buy to upgrade rc cars.
It might involve you doing a bit of soldering but it is not hard to do and all the work most people could manage.
Let me know how you get on or if you need further assistance ok
Aug 22, 2009 | Tyco Rc Batman Monster Jam Series Monster...
Backlight wont turn off
mine had the same problem when i left my sd card adapter in my phone without my card in it. put my card back in it or took the adapter out while the card was out and it works perfect.
Jan 20, 2009 | Motorola Mobility Moto Q
Health & Beauty Logo
65 people viewed this question
Top MK Battery Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a MK Battery Health and Beauty Expert? Answer questions, earn points and help others
