What is the problem when sometimes it will turn on but after a minute it will automatically turn off when I try to turn it on there will no power light at all
Posted by Noelita Fernandez on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 56,011 Answers
Failing power supply
Posted on Aug 18, 2019
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
My computer automatically turns off and again opens automatically.it sometimes opens for about 10 minutes and again restarts or turns off
hmm try changing a new or known good memory, if not , its time to check your antivirus, if not working last option re-install your OS
May 11, 2009 | Biostar P4M800-M7A Motherboard
Our Oven seems to be stuck in the Self-cleaning mode
Have you tried unplugging it and then reapplying power after a few minutes? Sometimes a power down/up cycle will reset the logic..
Sep 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Computer freezes, No Keyboard No mouse, but machine keeps on running
Try to check the capacitors of the motherboard, maybe some of them are damage, they can cause this kind of problem
Nov 20, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Set turns itself on for no reason (and sometimes off)
on menu, pick customize, then set the video input sensor to off.
Dec 31, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
