I turned it off before bed and when i got up this morning my tv will not power on
Posted by Brantley Hodge on
andrew Mocumie
    New Friend:
  • 4 Answers
Transformer dead
Posted on Aug 17, 2019
Don A
  • Televison & ... Master
  • 2,620 Answers
Unplug it from the electrical outlet. On the physical TV, depress the power button (on button) and keep it depressed for 30 seconds. Release the button. Plug the TV back in. Try turning it on with the physical button, not the TV remote.
That might reset the TV.
You have not indicated if there are other symptoms such as a blinking light. And we have not ruled out such things such as a battery in the remote being loose and thus the remote fails to work. Or, something physical is blocking the signal from the remote. Or a fuse has blown to the power outlet that the TV is connected to. Such things have to be ruled out.
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
II turned my tv off to go to bed but when I went to turn it on this morning it would not come on.
going to have to look inside the set, follow the power cord to the main ac fuse and see if bad or good.
Dec 22, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
When i went to bed, i turned the Daewoo TV off. Then when i tried to turn it on in the morning there was no power. No lights come on but the fuse is fine.
A total failure can be a result of a power failure in the TV. so to check the main power which is a SMPS unit - switch mode power supply- remove plug, remove the poser section and check;
check for tips on the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
May 19, 2011 | Televison & Video
Last night I was watching TV just fine. I turned off the TV when I went to bed and then tried to turn it back on this morning when I got up. It wont turn back on and I have checked to make sure that there...
Check ur power source?Tries tv unplug,replug the tv back like about an hour later.Now the tv are resetting it self back to the factory setting.The tv should work now.If still have the same problems,some how ur power supply board is causes and is not providing the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
