Question about Refrigerators
French door Insignia freezer its defrosting & a small box flashing & I don't know what it means. WF26FD9-1 26.6cu. ft.
Posted by Louise Nelson on
Chris Walker
    Top Expert:
  • Refrigerators Master
  • 1,551 Answers
Posted on Aug 18, 2019
5 Related Answers
Anonymous
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
Anonymous
  • 531 Answers
SOURCE: icing in freezer
you have defrost problem
Posted on Apr 06, 2009
CongressmanT
  • 8 Answers
SOURCE: My LG bottom freezer, french door evaporator fan
Defrost heaters are not coming on. Check with multi meter..is it frost, or ice freezing under the fan-blades. That my friend is a blocked drain hole. Otherwise ohm out defrost heater should read 30to69 ohms of resistance. Timer may be stuck, or a hi-temp safety switch is not closing (a small disc at the top of the coils) when it comes out of defrost. Carweful with that gun, Jim! Too much heat warps all that chinese plastic. Chris in bigbEar
Posted on Apr 20, 2009
Anonymous
SOURCE: My Samsung French Door RF266ABPN has a warm
I have read that if you unplug the unit and plug it back in again, it will "reset" it. I would wait 15 or so minutes before replugging just to be sure. Of course, this solution doesn't preclude the problem from happening again - sounds like a manufacturing defect to me.
Posted on May 21, 2009
Anonymous
SOURCE: Set defrost timer on Paragon Electric Defrost-O-Matic
the problem is not necessarily with the timer. it seems you have more than ample time and time allocations to perform a complete defrost. most walk ins should have roughly 25-40 minutes of defrost every 4 to 8 hours. if you defrost with a heating element, you may have a problem with the strength of the element,or the element may be pulled away from the coil. you could also have a problem with the defrost thermostat(allowing the defrost to terminate prematurely)
Posted on Jun 17, 2009
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
Jul 07, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
The freezer on my French door fridge is forming frostl. Why is this happening.
Is it frost on the freezer inside back wall or inside freezer towards the freezer door on the top of inside freezer box. If back wall then you have a defrosting problem. If it is towards freezer door then you have door seal problem and moist room air is getting inside your freezer.
Oct 13, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
What causes the freezer to frost up heavy
defrost cycle not working properly...
bad thermstat
bad heating elememt in freezer
bad defrost cycle timer...
Aug 27, 2014 | Samsung 28 Cu Ft Stainless Steel French...
Er if code comes on. I have let it defrost for 4 hours. Code disappears and then reappears. I would like to know how to fix it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
