If you still have the original download media, use it to reinstall the program.
If you no longer have the files you originally Nova Development downloaded, contact them directly for your registration information and instructions on how to download and reinstall -
http://support.novadevelopment.com/support/home
SOURCE: I installed Print Artist Platinum 23 and when i
anychance of a copy of this and i,ll see if it works on my pc and let you know..i,am a pc engineer and will do my best to help if i can email me at [email protected] if you would like my help
SOURCE: Want to transfer Print Artist 4.0 Platinum by
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
SOURCE: every time I try to boot up print artist platinum
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
SOURCE: print artist platinum 22 does not want to install
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
SOURCE: I purchased Print Artist Platinum
either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install
