Question about Calypso Watches
I have replaced the battery in my Calypso watch. On the cover it says 'short to reset'. what do I need to do?
Posted by Ted Wightwick on
Ken Hanie
Ground the positive post of battery to the case with something metallic like tweezers! It will start working immediately!
Kea
Posted on Aug 20, 2019
4 Related Answers
Anonymous
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
Anonymous
  • 59 Answers
SOURCE: replace a battery cover in a guess watch
Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
which take lots of time try expert watchmaker hope you get it fix.
even thought it fix some time it's lost capability to keep your watch save from water.
hope this info help
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Posted on Oct 01, 2009
Anonymous
  • 98 Answers
SOURCE: I have a Pulsar PQ2001 LED wrist watch requiring
You need to CAREFULLY peel back that sticker and on either side of that metal clip is a way to unclip it. I really would not recommend someone changing any of their batteries unless its a "cheapo" watch! If you touch the wrong area with the tweezers you could end up having to send it in for repair! Best bet here is to take it to a reputable watch repair shop and let them do it!
Posted on Jan 15, 2010
ansel_albert
Ansel Alberto
  • 248 Answers
SOURCE: replaced battery but unable to
there is reset button beside the battery or you have another option is to push all the buttons of your watch to reset and you can now set the time, date and other that had to be set manually..
Posted on Jul 09, 2011
How to place the back on
It is highly recommended that you take it to a jeweller's to replace the battery. If the battery is replaced you need to reset the watch by push/short internal reset switch after replacing battery.
Oct 14, 2015 | Timex Mens T2N723 Intelligent Quartz...
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing...
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Jan 02, 2011 | Disney Lorus Rare Musical R2306AX Watch
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
NEW BATTERY. NO CHIME OR BEEPS ON THE HOUR,TIMMER, AND ALARM WHAT CAN I DO TO FIX THIS PROBLEM
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry2.gif & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: [email protected]
web: www.goamfix.com
Sep 14, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Oct 01, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Watches Logo
206 people viewed this question
Top Calypso Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Calypso Watch Expert? Answer questions, earn points and help others
