Question about Home Security
How to change combination on a sentinel safe with a keypad
Posted by Rollie North on
1 Related Answer
ArcAiN6
Chris May
  • 152 Answers
SOURCE: want to change 6 key combination on safe to different one
I can't seem to find a product manual for you, but i may be a step closer. Winchester safe's are made by Granite Co.
Here is a site that may be able to help you, they are in Texas, and should be able to provide you with the information you require to change the code.
http://winchestersafes.com/
Posted on Jun 01, 2009
My combination will not open my canon safari 24 gun safe
The Canon safe, if not modified, comes with a digital pushbutton keypad that activates the interior release mechanism. Without exact details (clicks?..buzzes?..beeps?..totally dead?) an answer is hit or miss.
Adding to the obvious..a good battery, no visible damage, forgot the combination, wrong button sequence...
1. the keypad only sends the open signal for the correct combination after keypad is pressed.
2. if it accepts the combination (no error beep), is the signal accepted to unlock.
3. is the interior mechanism trying to unlock.
If you can determine which stage is failing..it will determine if there's a fix.
If all three are working, you hear a little click after..the door/lever may have pressure on it.
If any one of the three cannot be confirmed..no entry with the pad!
Oct 07, 2016 | Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How do I change the combination on I have a paragon digital lock & safe
    TO SET UP OR CHANGE A USER CODE
    1. With the door open, locate the red button on the back of the door near the hinge.
    2. Press the red button and listen for the beep.
    3. Immediately enter your new passcode (3-6 digits long)
    4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
    NOTE:
    This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
    first passcode entered.
    SETTING UP OR CHANGING A MANAGER PASSCODE
    1. Open your safe with the passcode you wish to change and leave the door ajar.
    2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
    New user passcodes may be 3-6 digits long.
    3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
    http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
    Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
    Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
    You can turn off the "Beep" sound of the keypad by entering the code 633.
    To turn the "Beep" sound on, enter the code 66
    Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
    How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
    How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
    Sep 01, 2010 | Sentry Fireproof Safe
    Changing Combination of Bunker Hill digital floor safe
    there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
    Aug 06, 2009 | Check Point Network Adapter
    Want to change 6 key combination on safe to different one
    May 08, 2009 | Computers & Internet
    How i change caracter's in game, marvel vs street fighter for psx? what are the corret pressing button for change the 2° caracter in game? thank you
    For the main mode of this game, switching between characters is not an option, but you can switch between characters in crossover mode, however here are some interesting secrets involving this game.
    Playstation only [edit] EX Options To enable EX Options, beat the game once. Then at the title screen, highlight Options, hold playstation-button-select.png, and press playstation-button-start.png.
    [edit] Enable the Hidden Helpers To enable Shadow and Sentinel, simply beat the game once. They can be picked by moving to the bottom of the screen and pressing Down when highlighting Iceman or Colossus.
    [edit] Play as Hidden Characters To enable a hidden character, simply beat the game with their counterpart. Then follow the instructions to select them.
    Beat with Unlock Selection Venom High-Speed Venom Highlight Chun-Li and press Up. War Machine Hyper-Armor War Machine Highlight Zangief and press Up. Morrigan Lilith-Style Morrigan Highlight War Machine and press Down. Mega Man Roll Highlight Mega Man and press Right. Mega Man Magnetic Mega Man Highlight Mega Man, hold playstation-button-select.png, and pick him. Hulk MSH Performance Hulk Highlight Ryu and press Up. Chun-Li Shadow Lady Highlight Gambit and press Down. anybody Onslaught Highlight Wolverine and press Down. [edit] Fight the Hidden Character The requirements have been simplified a lot for the PSX version. Just do the following:
    • Don't lose a round.
    • Don't continue.
    • Don't have a second player join in.
    • Get the following special finishes during the last round:
    Team Finishes MSH-Performance Hulk & Sentinel get 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Lilith-Style Morrigan & Shadow get 4 Hyper Combo, Variable Combination, or Variable Cross finishes. Hyper-Armor War Machine & Sentinel get 5 Hyper Combo, Variable Combination, or Variable Cross finishes. Roll & Shadow get 2 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. High-Speed Venom & Sentinel get 3 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Shadow Lady & Shadow get 4 Variable Cross finishes, and 2 Hyper Combo, Variable Combination, or Variable Cross finishes. [edit] Use the same character in a team Beat the game once, and you can do teams like Gambit + Gambit.
    [edit] Start off in a different mode You can pick Ryu or Zangief and have them start off in their other modes by doing the following:
    Mode Method Ken Mode Highlight Ryu, hold playstation-button-select.png, and pick him. Akuma Mode Highlight Ryu, hold playstation-button-start.png, and pick him. Mech Zangief Highlight Zangief, hold playstation-button-select.png, and pick him.
    Apr 14, 2009 | Capcom Marvel Super Heroes vs. Street...
    Home Security Logo
    245 people viewed this question
    Top Home Security Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a Home Security Expert? Answer questions, earn points and help others
